I set up this topic to warn fellow makers. In case someone has the fancy idea I had, to drive two Sonoff Minis from a euro-style 2-gang switch which usually shares one live wire to two wires going to the light fixtures like the one below, then just don’t do it.
So that I may kill any dumb ideas in their infancy;
The S1s are Ground pins of the low voltage system and isolated from mains. If you first tie S1 of two minis, together, there should be no risk as you have connected just two grounds.
Now, when you flip the switch, you toggle between S2 of mini1 and S2 of mini2, which are GPIO 14 pulled high. They are happy to receive ground.
