Hello Community
I am looking for a device allowing to make my switch connected to HA
it is a passive switch, meaning that there is no current going through:
it is a rotating switch composed of 3 wires left (yellow) /neutral (black) /right (Blue)
When rotating the switch it connects either the left-neutral or the right-neutral. when the switch is idle, nothing is connected. So it is working like two push buttons that could not be pushed at the same time
So i need as a solution a device:
- connected (WIFI if possible)
- preferably using 220V as supply power (could also work with included batteries, but i have 220v Wires available)
- Able to passively connect one cable (Neutral) to the left wire, the right wire, or not connected
- nice to have: to be able to capture when the physical switch is pushed (i can live without this function)
When i see over the net all solutions of connected switch are not passive. They are sending current, sometimes AC or DC but no one seems to operate in passive mode.
Anyone in the community able to help me ?
Many Thanks in advance
