Greetings-
I am new to HA and so far LOVING the power and customizability. Currently I am hitting 1 major roadblock in the process of moving all of my automation to HA. I am missing 2 switches from my Tuya integration. These 2 switches are of the same model and are the only 2 of this model I have.
Not sure if the Tuya code needs to be adjusted but I just can’t seem to get these switches into HA. Any and all help is appreciated, thank you!
Not all tuya switches are recognized by the tuya integration. If they are not, there is a workaround.
Create 2 scenes in the tuya app. One scene where the switch is on, one scene where the switch is off. The scenes will be pulled in homeassistant, and then you can turn on the switch by activating the ‘on’ scene, and turn the switch off by activating the ‘off’ scene.
