2 Temperature Sensons on MQTT
I have an Acurite Tower Temp sensor and a Nexus Pool Temp Sensor
under rtl_433 both are on topic home/rtl_433
here’s configuration.yaml. As you can see I’m playing around with entity_id and unique_id. Nothing is working. The sensor for Acurite is correct however the Nexus is just the C measurement of the Acurite.
How can I differentiate between these two sensors?
I don’t know why my preformatted text isn’t working
  • platform: mqtt
    state_topic: ‘home/rtl_433’
    unique_id: ‘12644’
    unit_of_measurement: ‘F’
    value_template: ‘{{ ((value_json.temperature_C * 1.8) + 32)|round(1) }}’
    sensor 1:
  • platform: mqtt
    name: ‘Outside Humidity’
    unit_of_measurement: ‘%’
    value_template: “{{ value_json.humidity }}”
    sensor 2:
  • platform: mqtt
    name: ‘Hot Tub Temp’
    entity_id: ‘sensor.hot_tub_temp_2’
    unit_of_measurement: ‘C’
    value_template: ‘{{ value_json.temperature_C }}’
Please format your pasted code correctly:
You don’t appear to have an entity_id for the first sensor.
adding an entity id doesn’t seem to affect it. both are reading from “temperature_C” in MQTT
Please format your pasted code correctly.
  - platform: mqtt
    state_topic: 'home/rtl_433'
    unique_id: '12644'
    unit_of_measurement: 'F'
    value_template: '{{ ((value_json.temperature_C * 1.8) + 32)|round(1) }}'
sensor 1:
  - platform: mqtt
    name: 'Outside Humidity'
    entity_id: 'sensor.outside_humidity'
    unit_of_measurement: '%'
    value_template: "{{ value_json.humidity }}"
sensor 2:
  - platform: mqtt
    name: 'Hot Tub Temp'
    entity_id: 'sensor.hot_tub_temp_2'
… and while i was explaining how to format your code, you already it! Good, now it’s easier to read.
Unless you have a special need to use sensor, sensor 1, sensor 2, just leave the first sensor: and delete the other two.
Try this:
  - platform: mqtt
    unique_id: '12644'
  - platform: mqtt
  - platform: mqtt
As @123 said you should only have one sensor: block declaration.
I had tried that. Here is the individual dump of the MQTT. Both readings seem to be coming from temperature_C
{"time" : "2019-01-18 00:57:24", "model" : "Nexus Temperature", "id" : 174, "channel" : 1, "battery" : "OK", "temperature_C" : 39.900}
{“time” : “2019-01-18 00:49:51”, “model” : “Acurite tower sensor”, “id” : 12644, “sensor_id” : 12644, “channel” : “A”, “temperature_C” : 7.400, “humidity” : 69, “battery_low” : 0}
I’m far from being a Home Assistant expert but is that valid to specify entity_id in the sensor component’s configuration?
My understanding is that Home Assistant will automatically create the sensor’s entity_id using name. So ‘Outdoor Temp’ becomes sensor.outdoor_temp.
According to the documentation, you can specify a custom entity_id via the UI. I didn’t realize you could also do it in the configuration file.
37%20PM
Obviously the hot tub should be 100 something degrees but it is the same as the outdoor temp
All three sensors have the same state_topic. They get the same message.
The humidity sensor parses humidity from the message, but the two temperature sensors parse the exact same temperature. That’s why the show the same temperature.
You will have to create a more sophisticated value_template that also uses id and/or channel to identify the payload for the appropriate temperature sensor.
Yep. How do I set different topics. I catch all 433 transmissions and push to my MQTT server like this:
rtl_433 -F json -M utc | mosquitto_pub -t home/rtl_433 -l -h 192.168.20.6
What identifies each temperature sensor, is it id or channel or both?
You’ll need to use that in the value_template to extract the correct temperature.
For example, id=174 might represent the hot tub’s temperature and id=170 is the outdoor temperature. You need to discover what identifies each physical temperature sensor and use that in the value_template.
one is Channel A and one is Channel 1. Any hints how to do it. I’m stumped. I actually tried that but don’t know much about value template
Try this:
  - platform: mqtt
    value_template: >
      {% if value_json.channel == 1 %}
      {% endif %}
  - platform: mqtt
  - platform: mqtt
    value_template: >
      {% if value_json.channel == "A" %}
      {% endif %}
Thanks. I actually got this to work right about the time you posted.
  - platform: mqtt
    unique_id: '12644'
    value_template: >
      {% if value_json is defined and value_json.id == 12644 %}
      {% else %}
        {{ states('sensor.outdoor_temp') }}
      {% endif %}
  - platform: mqtt
  - platform: mqtt
    value_template: >
      {% if value_json is defined and value_json.id == 174 %}
      {% else %}
        {{ states('sensor.hot_tub_temp_2') }}
      {% endif %}
@123
yours looks more compact and cleaner. I’ll try that as well tomorrow too. Next I tackle alarms.
I think I prefer your choice to use id instead of channel to identify the device. If I’m not mistaken, the 433MHz sensor’s channel can be selected by a physical switch. If the channel is changed then my code will fail to identify the sensor. Unless I’m mistaken, the sensor’s id cannot be modified and is a better choice as a permanent identifier.
I didn’t use an {% else %} because I think it’s not necessary. If the received message is not intended for the temperature sensor then it should just be ignored. The sensor’s existing value remains untouched.
So I seem to have it all wrapped up nicely
16%20AM
And I set an automation to notify me via Pushbullet when the temp goes below 95 F. Took the sensor out of the hot tub and a minute later - got a text.
automation 20:
  alias: Temp Alarm
    platform: numeric_state
    entity_id: sensor.hot_tub_temp_2
    below: 95
    - service: notify.mypushbullet
      data_template:
        title: "Hot Tub Temp Alarm"
        message: >-
          Hot Tub Temp Alarm, Bruh
Awesome! Been having too much fun with 433 MHz devices this week.
