2 way audio with Dahua VTO
Hi there,
I have a Dahua VTO installed, and I can start a call (2-way audio) through Dahua’s DMSS app with no problem and can talk through the VTO’s speaker. I’d like to achieve the same thing using Home Assistant. I have a wall-mounted tablet that I’d like to use to talk with the VTO. I looked at multiple integrations and add-ons to figure this out but couldn’t get anything working.
These are the repos I tried:
My VTO model is:
VTO2111D-P-S2
I have seen multiple people say these repos worked for them, but I can’t seem to make it work for me.
I am also thinking of using a tablet on the wall, home assistant and dahua VTO. So far, I have a script that starts DMSS on the tablet after ringing, but that’s not it.
Hello! I’m in the same boat. The Dahua VTO has a SIP server, but I can’t find any options to implement two-way communication. Have you managed to find a solution for it somehow?
I recently tried asterisk, but did not come to the winning end. In VTO runs sip server it would be good to connect to it. When I set up VTO as a sip client, I no longer received notifications on DMSS
I know that this information comes VERY late, but this solution worked for me!
I’ll try, I’m in the same situation.
I’m using this too. Works really well with my VTO2202
I tried the solution in vain.
I put the fix_vto_codecs.sh file in the config/ccab4aaf_frigate-beta folder. I ran the script using Advanced SSH & Web Terminal (I’m not sure if I did it correctly). I simply copied chmod +x /addon_configs/ccab4aaf_frigate-beta/fix_vto_codecs.sh into the addon and pressed Enter.
After that, I copied Felipe’s config, but unfortunately I don’t get any frames in Frigate.
hello.
I put the fix_vto_codecs.sh in the addon_configs folder. and ok
i run chmod command and ok
if i run the “echo:/addon_configs/ccab4aaf_frigate-fa/fix_vto_codecs.sh” apears and error like “no such file or directory”. but the file is in the folder and have permisions
when i put the echo command inside the config.yaml file. frigate dont have image :frowning:
I second this approach, although I can’t really help with the setup issues as I am running Frigate in a docker container.
