I have been running HA for a very long time and just noticed that I have two MQTT listed in the UI:
Orig. configured in YAML config
And now a new one under integrations?
The last one looks a little low in devices so does this mean I am running two instances of MQTT?
Anyway to clean this up? (If I have two instances)
Also I keep getting this warning - should I disable this in the add-on config setting it to false?
The integration connects to a MQTT service, the add-on provides an MQTT service. If your integration uses the add-on-MQTT server, you loose functionality if you disable the add-on.
So it is the same MQTT server under Add-ons that is used by the integration?
Okay! so then just leave it alone then…
What about the “quit_logs” warning shoukld I just ignore that also?
Thats the problem I dont know… The integration MQTT just popped up
I have had the MQTT configured through the YAML and the using the " Add-ons" since I started using HA. The integration part came later and more things just pop-up here?
Example I installed Deconz via the Add-ons and its working and then I get this in the integration page
Without any ignore button? so some times its hard to tell what to do
