2 Zigbee Wall 2-gang Switch on Different floors Entities linked
Hi guys, I have recently installed 2 Zigbee 2-gang switch on my hallway and at the top of my stairs that should control the lights along the stairs and hallway. Since its a 2 gang switch, how do I pair them that If i press the button on the light switch at the top of the stair, it will also update the toggle status at the hallway. Like a in a manual series.
I would like to ask also on how to Invert the light satus of the wall switch. Currently Moe’s ZS-EUB_1gang doesnt have that option to invert light status. I want the Wall Switch light ON when the Lights are OFF and OFF when the Lights are ON.
Looking forward to your assistance and advice. Thank you in advance. God Bless
Regards,
JP
There is a blueprint that can keep 2 switches in sync:
You can select the two switches and it will sync them to each other…
As for the light status, how (ZHA/Zigbee2MQTT) are the switches connected to HA?
Zigbee2MQTT often has control over more features of a device, for example status LEDs
