2019 DYSON HP04 integration - failed to discover the devices
I just purchase a Dyson HP04 and I ran into the following issue. here is my configuration.yaml file:
dyson:
  username: xxx
  password: xx
  language: GB
  devices:
    - device_id: "ZZ4-US-KNA5108A"
      device_ip: 192.168.1.148
And according to the log:
2019-07-12 08:33:11 INFO (MainThread) [homeassistant.setup] Setting up dyson
2019-07-12 08:33:11 INFO (SyncWorker_13) [homeassistant.components.dyson] Creating new Dyson component
2019-07-12 08:33:12 DEBUG (SyncWorker_13) [libpurecool.dyson] Disabling insecure request warnings since dyson are using a self signed certificate.
2019-07-12 08:33:13 INFO (SyncWorker_13) [homeassistant.components.dyson] Connected to Dyson account
2019-07-12 08:33:14 WARNING (SyncWorker_13) [homeassistant.components.dyson] Unable to find device ZZ4-US-KNA5108A in Dyson account
2019-07-12 08:33:18 INFO (MainThread) [homeassistant.setup] Setup of domain dyson took 6.3 seconds.
2019-07-12 08:33:18 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=dyson>
Has anyone been sucessful setting up Dyson with Home Assistant ?
Thank you for your help!
I just added one of my fans, but my device_id is not in quotes:
 device_id: ZZ4-US-KNA5108A
Thanks for your reply.
I tried without the quote and got the same error message.
Could you please share your configuration file ?
Did you put GB for the language or US ?
Thanks a lot
My fan is the TP04 but here is what i used:
dyson:
  username: [email protected]
  password: XXXXXX
  language: GB
  devices:
    - device_id: VV5-US-KEA0332A
      device_ip: 192.168.1.98
Thanks for your quick answer.
So the question becomes what is the difference between HP04 and TP04…???
Thanks for your help.
Did you update your fan to the latest firmware, I know mine did upon first start.
Yes I did.
Any other idea ?
Are you in the US ?
I am in the US
Did you get it to work with your Dyson HP04?
I have the same unit and can´t get HA to find it.
Same problem here
Same here. Also with HP04 (the other two older models work well).
I’m having the same problem… I’m in AU … it says “It’s not found in my account” … so it obviously is signing in? idk
Anybody have any luck? Same with my new HP04.
Sucks because you can’t change heat with voice, I was hoping hass would get around that issue.
Expect the next HA release will have the fix: https://github.com/etheralm/libpurecool/issues/4#issuecomment-564626610
Is there a way to implement it before they choose to update it.
I can’t seem to figure out how the other guys did it?
I just tested it just now and it seems to work fine… now all I need to do is find a card that will support everything I want in it… ie a graph of the temperature, details of the air quality and humidity… kind of like the glance card
