Thanks @javicalle for your reply.
My RFLink box is connected via USB to my Raspberry PI4.
I’ve reconfigured all remotes again in RFLINK Loader and can successfully control then from within RFLink Loader with the 10;RTS;;0; command.
I’ve enabled the log level as you suggested. I don’t get much more out of it than what I’ve already shared.
2020-12-28 11:38:20 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-28 11:38:20 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for smartweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-28 11:38:24 INFO (MainThread) [homeassistant.components.rflink] Initiating Rflink connection
2020-12-28 11:38:24 INFO (MainThread) [homeassistant.components.rflink] Connected to Rflink
2020-12-28 11:38:24 DEBUG (MainThread) [rflink.protocol] connected
2020-12-28 11:38:57 DEBUG (MainThread) [homeassistant.components.rflink] Sending command: UP to Rflink device: RTS_098832_0
2020-12-28 11:38:57 DEBUG (MainThread) [rflink.protocol] sending command: {'protocol': 'RTS', 'id': '098832', 'switch': '0', 'command': 'UP'}
2020-12-28 11:38:57 DEBUG (MainThread) [rflink.protocol] writing data: '10;RTS;098832;0;UP;\r\n'
2020-12-28 11:39:18 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~����`��fx����x��fxf~f�
2020-12-28 11:39:18 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �f�����������`���������`~f�~f
2020-12-28 11:39:18 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: f������~怘�
2020-12-28 11:39:42 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~����`��fx����x��fxf~f
2020-12-28 11:39:42 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ��f�����������`���������`~f�~f
2020-12-28 11:39:42 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: f������~怘�
2020-12-28 11:40:07 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~����`��fx����x�
2020-12-28 11:40:07 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �fxf~f��f�����������`���������`
2020-12-28 11:40:07 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ~f�~ff������~怘�
2020-12-28 11:40:31 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~����`��fx����x�
2020-12-28 11:40:31 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �fxf~f��f�����������`���������`
2020-12-28 11:40:31 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ~f�~ff������~怘�
2020-12-28 11:40:56 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~���
2020-12-28 11:40:56 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �`��fx����x��fxf~f��f���������
2020-12-28 11:40:56 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ��`���������`~f�~ff����
2020-12-28 11:40:56 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ��~怘�
2020-12-28 11:41:20 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~
2020-12-28 11:41:20 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~����`��fx����x��fxf~f��f�������
2020-12-28 11:41:20 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ����`���������`~f�~ff���
2020-12-28 11:41:20 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ���~怘�
2020-12-28 11:41:45 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~����`�
2020-12-28 11:41:45 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �fx����x��fxf~f��f�����������`��
2020-12-28 11:41:45 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �������`~f�~ff������~�
2020-12-28 11:42:09 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~����`��fx����x
2020-12-28 11:42:09 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ��fxf~f��f�����������`���������`
2020-12-28 11:42:09 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ~f�~ff������~怘�
2020-12-28 11:42:34 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~����`��f
2020-12-28 11:42:34 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: x����x��fxf~f��f�����������`�����
2020-12-28 11:42:34 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ����`~f�~ff������~怘�
2020-12-28 11:42:58 DEBUG (MainThread) [rflink.protocol] received data:
2020-12-28 11:42:58 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~����`��fx����x��fxf~f��f�
2020-12-28 11:42:58 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ����������`���������`~f�~ff�
2020-12-28 11:42:58 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �����~怘�
2020-12-28 11:43:22 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~���
2020-12-28 11:43:22 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �`��fx����x��fxf~f��f���������
2020-12-28 11:43:22 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ��`���������`~f�~ff����
2020-12-28 11:43:22 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ��~怘�
2020-12-28 11:43:47 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~����`��fx����x
2020-12-28 11:43:47 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ��fxf~f��f�����������`���������`
2020-12-28 11:43:47 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ~f�~ff������~怘�
2020-12-28 11:44:11 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: �~�~����`��fx����x
2020-12-28 11:44:11 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ��fxf~f��f�����������`���������`
2020-12-28 11:44:11 WARNING (MainThread) [rflink.protocol] Error during decode of data, invalid data: ~f�~ff������~怘�
My versions are as follows:
System Health
version |
2020.12.1 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
virtualenv |
false |
python_version |
3.8.6 |
os_name |
Linux |
os_version |
5.4.79-v7l |
arch |
armv7l |
timezone |
Australia/Sydney |
Home Assistant Community Store
GitHub API |
ok |
Github API Calls Remaining |
4964 |
Installed Version |
1.9.0 |
Stage |
running |
Available Repositories |
703 |
Installed Repositories |
3 |
Home Assistant Cloud
logged_in |
true |
subscription_expiration |
January 11, 2021, 11:00 AM |
relayer_connected |
true |
remote_enabled |
true |
remote_connected |
true |
alexa_enabled |
true |
google_enabled |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
Hass.io
host_os |
Home Assistant OS 5.9 |
update_channel |
beta |
supervisor_version |
2020.12.7 |
docker_version |
19.03.13 |
disk_total |
57.8 GB |
disk_used |
5.2 GB |
healthy |
true |
supported |
true |
board |
rpi4 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Mosquitto broker (5.1), File editor (5.2.0), Log Viewer (0.9.1), Git pull (7.12), TasmoAdmin (0.13.1), SSH & Web Terminal (7.8.0), Zigbee2mqtt (1.14.4.2), Node-RED (7.2.11) |
Lovelace
dashboards |
2 |
mode |
auto-gen |
resources |
0 |
Again, I’m at a loss why the upgrade broke RFLink. Any help in resolving this would be much appreciated.
