This used to work. After the 2020.12 upgrade, it kept complaining. I had to comment out the automation (and lovelace_gen integration) to get past safe mode.
- service: switch.turn_off
data: {}
entity_id: {{ trigger.entity_id }}
123
(Taras)
December 14, 2020, 4:29am
42
You may want to review the description of blueprints because thatâs not what they do. Automations continue to exist. A blueprint separates data from logic. In other words, you can create a blueprint to generate an easily configurable automation (among other things).
@123 whoops. What I meant was replace automation templates with blueprints. Iâm with yaâ blueprints are not automations on their own.
Maybe, maybe not. But telling me what theyâre not isnât changing my mind.
I understand blueprints donât work the exact same way as templates but, for my purposes, they may solve the same problem.
If you have a different perspective feel free to share. But telling me what theyâre not doesnât make either of us smarter.
It does make one of you much better informed though
123
(Taras)
December 14, 2020, 4:47am
47
I also explained what they are but I guess it was overlooked or failed to make an impression. Thatâs why I also suggested to review the documentation.
Regardless, my automation with a template no longer works. I assumed posting that here might get some of the developersâ attention.
Gizmo
December 14, 2020, 5:00am
49
paradinglunatic:
Did you read the breaking changes?
âCertificate Expiry In order to optimize stability and performance of Home Assistant, time based sensors should use only absolute time values (store the date of the event) and not relative time values (seconds from event), so the value doesnât change each second. The Certificate Expiry integration has both of them, so to adhere to Home Assistant architectural design rules, the offending relative time sensor is now removed. If your configuration was based on the relative time sensor, please switch to the other one. (@chemelli74 - #42338 ) (cert_expiry docs)â
Is there a work around to get it working?
Edit:
Nevermind. I just reloaded the integration and manually created a number of days until expiration sensor using the timestamp sensor for cert expiry.
sensors:
certexpiration:
value_template: '{{ ((as_timestamp(states("sensor.cert_expiry_timestamp_hostname_dyndns_org"))-as_timestamp(now())) | int /60/1440) | round(0) }}'
unit_of_measurement: 'Days'
friendly_name: 'Days Until Cert Expiration'
If the syntax youâve posted is exactly what you have in your configuration, I can tell you categorically that it has never worked, because you have a single line template that is not enclosed in quotes. This is not something that has happened in this version, it has always been the case.
sparkydave
(đŠđș Dave)
December 14, 2020, 5:04am
51
Wait while I get my popcorn
aidbish
(Adrian)
December 14, 2020, 5:08am
52
I suggest you speak to the dev of the custom component integration for that issue
dammit, youâre right where it matters most. Quotes fixed it and re-enabled lovelace_gen, which I thought would be unrelated. I know it worked before because⊠well, it was working for a while. Thank you!
(Taras)
December 14, 2020, 5:12am
54
This ought to fix it:
entity_id: '{{ trigger.entity_id }}'
I agree with mf_social. An unquoted template is invalid in all releases, not just the most recent one.
You would have to use a line-continuation character to permit the use of an unquoted template.
entity_id: >
jdmartinez
(Juan Diego MartĂnez)
December 14, 2020, 5:46am
55
I cannot upgrade. When I try it fron Supervisor, I get âSupervisor error: unknown error. See Supervisorâ
My installation is docker-based and Iâm currently in 0.118.4.
Any ideas?
Thank in advance
onlinegill
(Sukhpal )
December 14, 2020, 6:14am
56
Same here,
Running HA on Proxmox
System log shows :
20-12-14 06:09:29 ERROR (SyncWorker_4) [supervisor.docker.interface] Canât install homeassistant/qemux86-64-homeassistant:2020.12.0 â 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.0&fromImage=homeassistant%2Fqemux86-64-homeassistant: Internal Server Error (âGet âhttps://registry-1.docker.io/v2/ â: context deadline exceededâ).
20-12-14 06:09:29 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
100lv
(100lv)
December 14, 2020, 6:31am
58
After the upgrade I have 2 issues:
HACS is not loaded
Cert Expiry is not working.
Iâm running HA Core in Docker on Ubuntu
Juhurus
December 14, 2020, 6:32am
59
update error:
20-12-14 05:17:25 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-homeassistant:0.118.5 to homeassistant/raspberrypi3-homeassistant:2020.12.0
20-12-14 05:17:25 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-homeassistant with tag 2020.12.0.
20-12-14 05:17:35 ERROR (SyncWorker_2) [supervisor.docker.interface] Canât install homeassistant/raspberrypi3-homeassistant:2020.12.0 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.0&fromImage=homeassistant%2Fraspberrypi3-homeassistant: Internal Server Error (âGet âhttps://registry-1.docker.io/v2/ â: dial tcp: lookup registry-1.docker.io : no such hostâ).
20-12-14 05:17:35 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
perhaps server down?
EDIT:
I just checked in supervisor/system and it says:
Version
2020.12.6
Newest Version
2020.12.6
so it seems it has been updated, iâm confusedâŠ
but Supervisor/dashboard says:
Update Available
Home Assistant Core 2020.12.0
You are currently running version 0.118.5
VDRainer
(đ»)
December 14, 2020, 6:35am
60
100lv:
HACS is not loaded
Doesnât it work, or is the icon not showing?
If itâs the icon, press CTRL-F5
BertrumUK
(Neil B)
December 14, 2020, 6:45am
61
Cert Expiry is a breaking change. Just delete the current one and add it back through Integrations.
I also updated my Pi4 and HACS is working fine. Will reboot my Pi3B+ later to see if that clears it.
**** Rebooted my Pi3B+ and HACS is back ****
