Hi.
I’m not sure if this is the right place to post this, but it is Home Assistant OS I’m using, so…
In the supervisor, I tried to to change the repository pointing to Zigbee2MQTT, since there seems to be a change.
But after I did that, the community addons repository disappeared.
I tried to put it back using the URL found here: https://addons.community/
But what happened then, is that both the Zigbee2MQTT repo and the community addons repo disappeared!
So it seems that it’s not possible to add repositories at the moment.
