2021.11: Icon picker, device links and entity categories
Anthem AV integration is Unavailable.
Aaron I believe I have the steps for what I did in chrome to get it working. Posted some of the screen shots in the GitHub issue I created. Similar to your docs except where to find the correct code. I can help if needed.
I’m having the same issue. How do I run automations off the “control” entity?
Nope, still there unfortunately.
Are your cost statistics still accurate in HA even with the warning. As I mentioned mine are fine and match back to the Efergy Dashboard so not really sure what the Warning is actually warning about :thinking:
(if all is OK with your sensors and you want to just remove the warning you can always change the logging level to exclude warnings for this component, though that’d obviously exclude any Efergy related warning. I haven’t done this, but just in case you wanted to :+1: )
Hello there;
The version update was successful. After the update, I uninstalled Tuya V2 and installed Tuya. After installing 4 Device 7 assets were not installed. In addition, I have 1 siren registered on tuya now, I could use it with automation, now I was hoping that this update would be installed directly, but the room did not come. :frowning: Can you help me please?
Tuya thermostat does not work with Simple Thermostat Card anymore, no reaction on changing the temperature and some symbols are missing. On HA climate card are no options anymore, can’t set min and max temperature, steps, decimals
Went back to core-2021.10.7, everything’s fine again.
Anyone else following the instructions for the Simplisafe integration running into an “invalid authentication” error?
I did in the beta in chrome. I needed to open the console editor (in chrome) to find the correct code. I know Aaron uses safari and it worked for him per his docs. I opened a GitHub issue that is closed that I pasted pictures showing where the code is
The Entity separation is surprisingly powerful and brings so much needed clarity! It finally made me clean up all the unnecessary entities, sensors, so much stuff I don’t ever need. To an extent where HA starts up noticeably faster. Thanks!
Just upgraded from 2 versions ago (I tried the last one, but Tuya you know
) and
 and now not only I can’t use Tuya but even Xiaomi Miio. Can’t login in any of two service, and all is correct, passwords ecc copied from clipboard, tried login on apps and they’re OK. I don’t know what to do :confused:
Your entities still show Tuya v2, I just see Tuya as integration.
@bschatzow : That worked! Thank you kindly for your help.
Anyone has EFERGY?
I put ion the new integration discovery, the efergy_token but it gives error
UNEXPECTED ERROR
Am also seeing this. The categories show up fine on my device views, but the main Overview (default) view is mostly empty after the update. I have three areas showing, and see no difference between them and the missing areas / devices.
Are you using?
if yes, remove it as it’s the source of the problem.
I was indeed. And it looks like v.6 was just released to fix the problem.
Thanks Petro!
I had it fixed. Re-installing the integration and setting back up alle the camera’s worked. Don’t forget to set the RTSP port from 554 to whatever port you are using for your camera’s. No idea what caused the issue, tho.
I had to add a line in my vicare-config
heating_type: heatpump
In the documentation it says it is optional - Viessmann ViCare - Home Assistant
But in HA it gave me an error (i did not have the line in my configuration.yaml):
Invalid config for [vicare]: value must be one of [‘auto’, ‘fuelcell’, ‘gas’, ‘heatpump’, ‘oil’, ‘pellets’] for dictionary value @ data[‘vicare’][‘heating_type’]. Got None. (See /config/configuration.yaml, line 39).
After adding the line no errors any more.
My illumination channel is still missing (HmIP-SMI).
++ please help me ::frowning:
