BebeMischa
(Bebe Mischa)
November 4, 2021, 10:36pm
267
Atomic is no more a problem with todayâs update. If you use Atomic calendar, go to HACS and click update.
If your problem was caused by this, then itâs gone nowâŠ
petro
(Petro)
November 4, 2021, 10:38pm
268
The hit f12 and see what custom card is causing the problem by looking at the console
uSlackr
(Greg Martin)
November 4, 2021, 10:39pm
269
Keep in mind you have until 2022.1 before it really breaks
thank you⊠but, where to get a logs, when tablet is just loading⊠can I see any logs in supervisor about external device trying to connect? ⊠isnt there any change in core that is not working well with old android 4.4.4 on my tablet? 2021.10 had no problem with it⊠thanks!
aidbish
(Adrian)
November 4, 2021, 10:41pm
271
Are they custom cards, if so check with the dev of those to see if update is required
aidbish
(Adrian)
November 4, 2021, 10:43pm
272
Other custom cards are also having some issues, the mini media card was i believe one of them
aidbish
(Adrian)
November 4, 2021, 10:45pm
273
Do you have custom cards?
if so do what petro told you to do and hit F12 to see what custom card is affecting you, then you at least know which custom card dev you need to contact to get it fixed
yes, I am using some custom cards, I will try F12⊠thank you!!
how do we get someone to look at and approve an update to an integration?
home-assistant:dev
â lewei50:iammeter
opened 12:55AM - 27 Apr 21 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N⊠OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [x] Code quality improvements to existing code or addition of tests
## Example entry for `configuration.yaml`:
Supplying a configuration snippet, makes it easier for a maintainer to test
your PR. Furthermore, for new integrations, it gives an impression of how
the configuration would look like.
Note: Remove this section if this PR does not have an example entry.
```yaml
# Example configuration.yaml
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [x] No score or internal
- [ ] đ„ Silver
- [ ] đ„ Gold
- [ ] đ Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
ttmetro
(Bernhard Boser)
November 5, 2021, 2:25am
278
I also get
Database error during schema migration
and related errors. Iâm using mysql.
1BH
November 5, 2021, 6:08am
279
Restarted again now, and my Tuya integration started working again in 2021.11 with same values as for 2021.10.7, so seems Tuya undid their issue. For now⊠Local connections were never down in the first place.
I am still particularly worried by Tuyaâs expiring API accounts - if they intend to keep the policy (be that 12month expiry or 1 month expiry) then HA should move away from using the cloud based service.
After update the âimap email contentâ works any more. (gmail)
nickrout
(Nick Rout)
November 5, 2021, 6:12am
281
Do you mean doesnât work any more? Or are you just congratulating the team on something not beaking?
Yes, sorry, doesnât work any more.
nickrout
(Nick Rout)
November 5, 2021, 6:16am
283
Thatâs OK we all make typos. I suggest you look at logs, perhaps with logging turned up on the imap integration. Then you can post on github if this forum canât help
viperhansa
(Hans Ă
ström)
November 5, 2021, 9:38am
284
Hi all!
Now when we got the Icon picker which is SUPER! , when will we be able to swipe between tabs instead of clicking tabs?
New guy here so if this have been addressed somewhere, i apologise.
Regards and keep up the good work!!
// Hans
fribse
(Kenneths Teknik)
November 5, 2021, 9:59am
285
Always nice to see progress, and I hope a lot of bugfixes.
Too bad that problems with the Xiaomi Miio integration is ignored, and that the icon selector is rather limited.
Iâm wondering why would you want to set up icons and easy selection in a card only, with multiple lovelace interfaces, that would require multiple corrections, whereas if you had put it in Customizations under Settings, it would be a global fix.
