2021.11: Icon picker, device links and entity categories
Did you find a fix for this? I have this happening in my Frigate cards
Next time please do NOT bump your question after 2 hours. Wait 24 hours.
The problem with Atomic Calendar card is fixed. Todayā€™s update of that card installed and all is fine now.
I just upgraded and had to do the whole tuya song and dance again. It added the devices but all the heaters are marked as unsupported.
Honestly, I donā€™t get it. It worked before you made the change, it worked after the change but with this last change itā€™s now marked as unsupported.
I update home assistant not necessarily for the features it adds but to be up to date with patches to vulnerabilities or other security risks but it just keeps breaking this tuya crap
sigh
For those using SolarEdge, after upgrading if you find several of your solaredge sensor entities missing, as stated in the release notes, its because they may have been defaulted to disabled. To enable them, go to the UI for the SolarEdge integration and enable the entities you want.
Ok, walking the docker back to 2021.10 restored the tuya heaters functionality, very welcome in these cold months.
I deleted my old config and was able to add it using the new built in integration. The sensors changed names but I had no real issues.
Octoprint UI intergration is not finished or not working ok - only one instance is possible, i had more than one in yaml before! I use this for CNC, LASER, and cutters! Now can connect only one printer, please fix this asap.
Onvif integration only one cam works has also some bug have two same cheap onvif ptz cams that do work on other software only HA cant be set.
Until this is sorted, you could use the mqtt plugin in octoprint, you can have more than one instance with different base topics
Report your issue on github if there is one, make sure to include logs. Already an issue
Getting the same as well. Had to re-add the integration after the update and it was working fine until I rebooted tonight. Several reboots and itā€™s still does not work.
Seems we have a Fix until the update is rolled out. Change your SmartLife password and reinstall the integration or change it twice with the last password being your normal password and restart HA
Unfortunately this did not help in my case. Tuya keeps on giving me ā€œLogin error (1106): permission denyā€ where it worked in last version. Any other ideas?
Also noticed another issue; the ā€œTrialā€ setup for IoT Core now seems to have a 1 month validity time, which makes it fully irrelevant. The license I got a few weeks ago seems to be for 12 months, which is also too short, but 1 monthā€¦
Broke my HomeKit Controller integration (pulls a Nest Thermostat from Homebridge)
Worked great up all the way up until 2021.10.7
After 2021.11.0 all sensors unavailable
Attempted to remove/re-add the integration and am completely unable to. It sees it broadcasting as a HomeKit device, but does not successfully add it. I cleared dialog box already, something along the lines of ā€˜Config flow could not be added(generated?)ā€™
Reverting back to 2021.10.7 for the time being
Sidenote: I know there is an official Nest integration, but it does not work with their Temp sensors, where as Homebridges integration does)
Do the device(s) show up on Tuya website?
It seems to me that temperature metrics are now missing from the new Octoprint integration - did I configure something wrong or is this just not implemented (yet)?
Yes, they do. And all worked a day ago before updating. Reverting to old version did not seem to help either however, so apparently something has happened on Tuya sideā€¦
@bandric1 I got 3 printers and 2 of those have Octoprint and both instances are added in HA, did you try to turn on all devices that are connected to Octoprint en restart HA? The thing is, with the old integration the printers did not have to stay on to be available, now if I turn off the printers all sensors get unavailable, and get ERROR in the logs about printers being not online.
Here my printers in the Octoprint Core integration:
Tuya workaround/fix by a guy from reddit. I did it now and it did fix Tuya fully, letā€™s see if it sticks. Perhaps it forces something on Tuyaā€™s servers.
I got mine workingā€¦ I logged into smartlife app on my phone, changed my passwordā€¦ then logged back in and changed" my password to my previous password. I rebooted my home assistant (actually rebooted the pi), and even with the 11.0 updated, tuya is working again."
I am so sorry to say that this update 2021.11 is one big issue for meā€¦ after several try-outs I am giving it up and restoring previous version 2021.10ā€¦ there is some big problem with lovelaceā€¦ until now my old Huawei tablet on the wall was working perfectly as my main dashboardā€¦ after update, it was not loading lovelace ( I have seen, that it was signed in, but loading and loading and loading my lovelace views) until all Home assistant just crashed. After this unsuccesfull loading on tablet also my PC desktop stopped to work, I couldnt see also some add-ons, log viewerā€¦ when there was some short whiles when I could see and use lovelace, not all entities had their iconsā€¦ now I really hope, there will be some new release that will fix this bugsā€¦ waiting for 11.1 just to try itā€¦ thank you :frowning:
As it is specific to your setup (no one else is having this issue), you are going to need to do some investigating. At the moment you have supplied no logs or other information to help pinpoint the issue.
