check problem with media-control its tend to clear out your lovelace view.
I am having problems with the MQTT. More than half of the devices are not connecting.
Although publish everything (checked with mqtt explorer), itās like MQTT broker donāt accept the connections.
Anyone else with same problem?
No MQTT is continuing to work well for me. Any relevant errors in your broker log?
Iām having a weird issue with the frontend not loading card backgrounds properly, see: https://imgur.com/a/VmBFWbi.
It only occurs if I am using the slower connection through Nabu Casa. Navigating to the page locally works as expected.
Itās often not the same cards. It occurs in both Chrome and Firefox and for a change Safari is actually ok (iOS mobile app).
If I refresh the home view or clear the cache on the home view it may change which card backgrounds disappear but if I refresh the page on another view then switch to the home view it displays correctly.
This only occurs when using 2021.11.1 downgrading to 2021.10.6 stops the issue occurring.
I actually load the background image with card-mod (different image for day / night). So Iām not sure if this is an issue with the Home Assistant frontend or card-mod. Thereās an error for card-mod in the browser inspector but Iām not sure if it is relevant.
Anyone else seeing this?
I had MQTT issues as well. I just restarted the broker and it all came good again
I restarted everything:
Mqqt broker, than Home assistant, than all the devicesā¦
Some devices that worked before restart, didnāt came up and some other devices came upā¦
I noticed a yellow warning icon next to the log entries of my TRADFRI on/off switch in the logbook. I assume itās a cosmetic bug related to the battery icon, which is related to the battery level again since this release (2021.11.0)
Ahh, you are absolutely right, not sure why this didnāt appear when I first tried it? So I concluded that it must be in the customization insted.
Oh well, it shows the mdi icons, too bad that the added hue icons doesnāt show up.
And after an update for the hue they show up as well, now thatās nice!
Yes @petro I readed the message but was expecting a log message saying that the task completed successfully ā¦ anyway nothing important here.
Check your logfile for errors and size.
It is the first int having the problem - not the second one. Try this:
level_template: "{{ ( state_attr('sensor.xx', '4503') | int(default=0,base=16) / 90 * 255 ) | int }}"
sorry, I do not understand exactlyā¦ what kind of problem is there with media-control?
** TTS is NOT working any more after upgrade either Nabu CASA or Amazon Polly only get āwhite noiseā when try to use/test from speaker.
**** Media Players are not shown in Lovelace have tried all usual clean cache try different browser (3) nothing
Working for me. Using Nabu Casa tts.cloud_say.
Any errors in your logs?
Sounds like you may have an issue with your media players. Get them working and TTS will probably work too.
What sort of media players?
Update your custom cards and then clear your cache. If that does not work, open the developer tools (F12). Go to the console tab and look at the error. Remove the offending custom card causing the error.
Im having the same issues. Running v.14.0. Cant see a newer version in HACS even though iāve enabled beta versions.
I cant even add new cards. Its like lovelace is locked.
Missing in the release notes that the Tesla integration has been removed. Although it was not working for months now, it is at least worthy to mention. There is a replacement custom integration installable via HACS: GitHub - alandtse/tesla: Tesla custom integration for Home Assistant. This requires a refresh token be generated by third-party apps to login.
That happened last month https://www.home-assistant.io/blog/2021/10/06/release-202110/#farewell-to-the-following
