Glad to see this was recognised and apologised for.
For those using Tuya devices, you should probably give ol @frenck a cheer and buy him a coffee as his herculean efforts of the last few weeks in fixing and adding support for all manner of their devices.
That would never be part of a Core release, as that is not a Core feature, but a feature of the Supervisor.
Nevertheless, that has recently added a feature to use external external data disk (using the UI).
Upgrade went smooth. Was hoping my Tuya device would appear again as it disappeared half way last month. It worked in 2021.10 but disappeared at an unknown moment
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:85
Integration: Recorder (documentation, issues)
First occurred: 19:40:21 (1 occurrences)
Last logged: 19:40:21
Error executing query: (MySQLdb._exceptions.OperationalError) (1054, "Unknown column 'statistics_meta.name' in 'field list'") [SQL: SELECT statistics_meta.id AS statistics_meta_id, statistics_meta.statistic_id AS statistics_meta_statistic_id, statistics_meta.source AS statistics_meta_source, statistics_meta.unit_of_measurement AS statistics_meta_unit_of_measurement, statistics_meta.has_mean AS statistics_meta_has_mean, statistics_meta.has_sum AS statistics_meta_has_sum, statistics_meta.name AS statistics_meta_name FROM statistics_meta WHERE statistics_meta.has_sum = true] (Background on this error at: https://sqlalche.me/e/14/e3q8)
Folks, I am on 2021.9.7, and want to avoid troubles with DST coming up this weekend. So I want to install 2021.10.7, and wait for all the bugs to get cleaned up in 2021.11 before migrating there. But the update option in supervisor doesnāt give me the 2021.10.7 option, only 2021.11.
How can I get it to update to 2021.10.7 in my situation?
after update core to 2021.11 Iām missing most of my entities in the ui controlled lovelace. They are not gone but just the just not showing up rooms are missing as well. Anyone else having this problem?
