Guys, just updated, but what does below mean?
2021-12-13 18:42:24 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that uses str for device registry entry_type. This is deprecated and will stop working in Home Assistant 2022.3, it should be updated to use DeviceEntryType instead. Please report this issue.
Stack (most recent call last):
File "/usr/local/lib/python3.9/runpy.py", line 197, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.9/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 331, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 318, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 121, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 629, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 596, in run_forever
self._run_once()
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1890, in _run_once
handle._run()
File "/usr/local/lib/python3.9/asyncio/events.py", line 80, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 500, in _async_add_entity
device = device_registry.async_get_or_create(**processed_dev_info) # type: ignore[arg-type]
File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 360, in async_get_or_create
report( # type: ignore[unreachable]
File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 74, in report
_LOGGER.warning(msg, stack_info=True)
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
