2021.3: My Oh My
I’d believe the logs. Probably caching, or needing to reload. Try ctrl+shift+r.
That must have been it, I just went to try installing it again and now it says the version is .3. Thanks everyone for the help!
This has been fixed in 2021.4dev
The change is here if you need to manually pull it in: Ensure startup can proceed when there is package metadata cruft by bdraco · Pull Request #47706 · home-assistant/core · GitHub
has anyone else been noticing the new developer-tools/service page is way slower than before?
Thought switching it to yaml mode might help, but that is so deprecated compared to the previous style (no entity search dropdown), it is no longer of much use (or, I should probably say it is not as user friendly as before)
It would be nice if at least the entity picker could be restored own the yaml mode version?
A simple automation.trigger and then selecting an automation takes a long time on a larger system…
also, it needs the eyes to cross the whole screen from top left to bottom right to perform the action
Also having issues i noticed yesterday. I havent checked yet what could be the issue.
the enitity picker is there in the yaml version, it just displays the name rather than the entity id
that’s the service picker…
ah my bad. although if you want to use the ui for most of it, pick the service and entity then click yaml mode
Unfortunately, if you have really problem, the meross add-on team doesn’t answer on github… :neutral_face:
Also noticed the addon isnt updated since 2020 december :frowning: Think we might not be able to use it anymore unless we can fix the issue
as said, on a larger system, this is really slow. Not all UI progress is progress really. Sure, on my test systems it all is fluid, even on a Pi3. but using a production system, the eye candy all starts to lag significantly, and tbh, is not very intuitive in the first place (yet)
Since no one has the desire to answer a couple of simple questions…
Does anyone know how someone can use the previous version fan integration as a custom integration?
I’ve pulled the files from the prior code but unfortunately there are three (maybe more) files that could affect the fan domain operation - the main integration along with the mqtt fan and template fan - and I don’t know where to start to keep the functionality with three different but interrelated integrations.
What I also don’t know is if there is any special connection between the fan integration and the cloud integration that would still prevent the cloud devices from accepting a speed list as opposed to a percentage.
and I’m not sure how fans that are automatically set up using other integrations (zwave, zigbee, etc) are co-mingled with the main fan integration so would they be set up to only use percent speed either way.
Is it even feasible to try to split all of these away from the built-in fan integration?
Yep, same here. And if i try to reboot HA after i get the error message, i get the message that it can’t reboot because of an ungoing process. When that process finishes after some time, HA reboots and i have the new version. The logs do not have any error after the update. The only error i see is the line where i tried to reboot myself, which it denied. Strange…
(Supported HA Supervised on Debian10 here, on a Core2Quad CPU. )
Yeah I am seeing that I have gaps of hours in my speedtests (using the integration with 30 mins tests)
It has only just started doing this and it does it a few times a day. If I manually call the service it works again till it stops for no reason. Every time it stops I have to manually restart it. So I disabled the auto run in the integration and now switched to an automation.
2021-03-11 15:00:01 ERROR (MainThread) [homeassistant.components.speedtestdotnet] Unexpected error fetching speedtestdotnet data: Unable to connect to servers to test latency.
  File "/usr/local/lib/python3.8/site-packages/speedtest.py", line 1489, in get_best_server
    fastest = sorted(results.keys())[0]
IndexError: list index out of range
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 151, in async_refresh
    self.data = await self._async_update_data()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 139, in _async_update_data
    return await self.update_method()
  File "/usr/src/homeassistant/homeassistant/components/speedtestdotnet/__init__.py", line 174, in async_update
    return await self.hass.async_add_executor_job(self.update_data)
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/src/homeassistant/homeassistant/components/speedtestdotnet/__init__.py", line 162, in update_data
    self.api.get_best_server()
  File "/usr/local/lib/python3.8/site-packages/speedtest.py", line 1491, in get_best_server
    raise SpeedtestBestServerFailure('Unable to connect to servers to '
speedtest.SpeedtestBestServerFailure: Unable to connect to servers to test latency.
I wonder if this would be better if I switched to a fixed server in the integration?
I see this behavior only with fixed servers.
*Auto Detect works fine.
It worked fine for me too till it didn’t in 2021.3.3
I get this error during upgrade from 2021.2.3 to 2021.3.3:
Translation Error: The intl string context variable “naam” was not provided to the string “Bijwerken van {naam} naar versie {versie}”
EDIT: Also when upgrading addons I get this error…
This has been posted many, many times before in this thread.
Before upgrading from 2021.3.3 to 2021.3.4 I ran Check Home Assistant configuration addon - which found something for the first time:
[02:12:12] INFO: Making a copy of your configuration for checking...
[02:12:12] INFO: Checking your configuration against this version...
[02:15:52] ERROR: The configuration check did not pass!
[02:15:52] ERROR: See the output below for more details.
Testing configuration at /tmp/config
ERROR:homeassistant.helpers.check_config:Unexpected error validating config
raceback (most recent call last):
  File "/usr/local/lib/python3.8/site-packages/homeassistant/helpers/check_config.py", line 147, in async_check_ha_config_file
    await config_validator.async_validate_config(  # type: ignore
  File "/usr/local/lib/python3.8/site-packages/homeassistant/components/automation/config.py", line 103, in async_validate_config
    await asyncio.gather(
  File "/usr/local/lib/python3.8/site-packages/homeassistant/components/automation/config.py", line 85, in _try_async_validate_config_item
    config = await async_validate_config_item(hass, config, full_config)
  File "/usr/local/lib/python3.8/site-packages/homeassistant/components/automation/config.py", line 63, in async_validate_config_item
    config[CONF_TRIGGER] = await async_validate_trigger_config(
  File "/usr/local/lib/python3.8/site-packages/homeassistant/helpers/trigger.py", line 49, in async_validate_trigger_config
    conf = await platform.async_validate_trigger_config(hass, conf)
  File "/usr/local/lib/python3.8/site-packages/homeassistant/components/device_automation/trigger.py", line 21, in async_validate_trigger_config
    return await getattr(platform, "async_validate_trigger_config")(hass, config)
grep: write error: Broken pipe
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
In /share/check_config.txt I can find this one:
e[01;37mFailed confige[0m
  e[01;31mautomation:e[0m e[31me[31m
    - Unexpected error calling config validator: 'device_registry'
Something wrong (syntax?) with my automations?
So… what to do next? Not brave enough to update to 2021.3.4 as long as this addon says WELLLLLLL we found some errors you better don´t upgrade because it might faillllll…
I already restarted HA and ran the addon again - with the same output…
Sounds like a problem with your configured devices.
