2021.4: For our advanced users ❤️
Comment: I think you have a typo.
Question: How did you get those rainbow brackets in VSCode?!?
As petro said the real solution is for the integration to be updated to support unique IDs. In the meantime via the bottom link in the popup you can navigate to the customize dialog where you can overwrite a few attributes, such as friendly name, icon, unit, …
What about this?
If anyone would like to see the soon to be deprecated named speed list get saved from deprecation…
I’ve requested that the old speed list options should be kept and I’ve had a suggestion from a dev that if a FR gets enough votes they would implement it.
Here is the FR. Please go there and vote it up.
Hi Gianluca, did you find a solution for the problem? I’m in the same boat: PZEM tasmota auto-discovery etc etc. For a while I thought to have solved the problem with a reboot of the tasmota but I was wrong, I tried even to upgrade to the latest tasmota release (9.2) with no luck … Please keep me in the loop in case you should get any clue, I need the PZEM to compare the energy spent against the energy produced by the solar panel in order to optimize the consumption (keep the bill low :-)).
Thank you,
Federico
Hi @kajmaj did you manage to find the issue here, i have the same issue and have tried for a week trying to resolved it - i even rebuilt and readded in thr addons that i have been using for a year with no issues. Cheers
Pedro
Hi @pedro.goncalves Yes. I did it. On RPi 4, I deleted db file => reboot => update => and after approx 17 hrs of waiting it was done.
Why it was such a long waiting I do not know but it is over :slight_smile:
okay so it seems to be a normal process for the upgrade, thanks i am just going to leave it for a few days and see how it goes thanks again.
If you find yourself trying again, just go straight to HA version 2021.5.3 and skip 2021.4.x. The database migration has been streamlined and takes place in the background. This is what I did.
Hi @sparkydave i’m currently on 2021.5.4 - i have been having this issue below since the DB upgrade :frowning: and it does not matter how long i leave HA to run - i have rebuilt it like 6 times. there has to be something i’m missing as this list goes on and on and on.
 2021-05-15 17:41:14 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.561443124472cf432abf04f is taking over 10 seconds
2021-05-15 17:41:14 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.803043132dc44f2229a332d is taking over 10 seconds
2021-05-15 17:41:14 WARNING (MainThread) [homeassistant.helpers.entity] Update of calendar.phases_of_the_moon is taking over 10 seconds
2021-05-15 17:41:15 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.bom_mandurah_max_temp_c_0 is taking over 10 seconds
2021-05-15 17:41:17 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.brandon_lamp is taking over 10 seconds
2021-05-15 17:41:17 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.living_room_lamp is taking over 10 seconds
2021-05-15 17:41:17 WARNING (MainThread) [homeassistant.components.light] Updating tplink light took longer than the scheduled update interval 0:00:05
2021-05-15 17:41:22 WARNING (MainThread) [homeassistant.components.light] Updating tplink light took longer than the scheduled update interval 0:00:05
2021-05-15 17:41:25 WARNING (MainThread) [homeassistant.components.switch] Updating tuya switch took longer than the scheduled update interval 0:00:15
2021-05-15 17:41:25 WARNING (MainThread) [homeassistant.components.light] Updating tuya light took longer than the scheduled update interval 0:00:15
2021-05-15 17:41:27 WARNING (MainThread) [homeassistant.components.light] Updating tplink light took longer than the scheduled update interval 0:00:05
2021-05-15 17:41:32 WARNING (MainThread) [homeassistant.components.light] Updating tplink light took longer than the scheduled update interval 0:00:05
2021-05-15 17:41:33 WARNING (MainThread) [homeassistant.components.systemmonitor.sensor] Updating systemmonitor took longer than the scheduled update interval 0:00:15
2021-05-15 17:41:35 WARNING (MainThread) [homeassistant.components.sensor] Updating bom_forecast sensor took longer than the scheduled update interval 0:00:30
2021-05-15 17:41:37 WARNING (MainThread) [homeassistant.components.light] Updating tplink light took longer than the scheduled update interval 0:00:05
2021-05-15 17:41:40 WARNING (MainThread) [homeassistant.components.light] Updating tuya light took longer than the scheduled update interval 0:00:15
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.mandurah is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.living_room_lamp_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.theatre_lamp_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.cassidy_lamp_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.brandon_lamp_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.patio_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.alfresco_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.activty_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.living_room_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.living_room_on_2 is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.dining_room_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.kitchen_back_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.kitchen_pendants_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.kids_bathroom_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.main_bathroom_on is taking over 10 seconds
2021-05-15 17:41:43 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.night_light_on is taking over 10 seconds
2021-05-15 17:41:44 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.db_size is taking over 10 seconds
2021-05-15 17:41:47 WARNING (MainThread) [homeassistant.components.light] Updating tplink light took longer than the scheduled update interval 0:00:05
2021-05-15 17:41:47 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.8023042313d3c4f22b426e73 is taking over 10 seconds
2021-05-15 17:41:47 WARNING (MainThread) [homeassistant.helpers.entity] Update of calendar.holidays_in_australia is taking over 10 seconds
2021-05-15 17:41:47 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.bom_mandurah_min_temp_c_0 is taking over 10 seconds
2021-05-15 17:41:50 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.56144431272cf432a3be94d2 is taking over 10 seconds
2021-05-15 17:41:52 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.brandon_lamp is taking over 10 seconds
2021-05-15 17:41:52 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.living_room_lamp is taking over 10 seconds
2021-05-15 17:41:52 WARNING (MainThread) [homeassistant.components.light] Updating tplink light took longer than the scheduled update interval 0:00:05
2021-05-15 17:41:55 WARNING (MainThread) [homeassistant.components.switch] Updating tuya switch took longer than the scheduled update interval 0:00:15
2021-05-15 17:41:55 WARNING (MainThread) [homeassistant.components.light] Updating tuya light took longer than the scheduled update interval 0:00:15
2021-05-15 17:41:57 WARNING (MainThread) [homeassistant.components.light] Updating tplink light took longer than the scheduled update interval 0:00:05
2021-05-15 17:42:02 WARNING (MainThread) [homeassistant.components.light] Updating tplink light took longer than the scheduled update interval 0:00:05
2021-05-15 17:42:03 WARNING (MainThread) [homeassistant.components.weather] Updating darksky weather took longer than the scheduled update interval 0:00:30
2021-05-15 17:42:03 WARNING (MainThread) [homeassistant.components.systemmonitor.sensor] Updating systemmonitor took longer than the scheduled update interval 0:00:15
Does this actually have a noticeable effect on performance? Or are you just worried about the log entries?
Hi @nickrout - i can not access the default lovelace interface 20sec to 30sec afer i restart home asssitant via docker. i can not restart home assistant from the normal settings area.
wow something strange just happned - i rebooted Home Assistant again via docker and so far it has not locked up - it’s been almost 5min :slight_smile: maybe rebooting HA until it finally works must have fixed something - not too sure, but happy i’m all working again.
Thanks to all for your ideas. Have a great day!!
edit… Spoke too soon, Home Assistant interface is blank again :frowning:
nm, post error
The automation trace is truly amazing! I’ve already fixed a couple of things.
At first I thought that the automation had to be editable to get the trace because that is where the SHOW TRACE button is located, but then I discovered the image icon. Maybe an Info Trace Edit column heading would help some of us. (I think that I tried the icon at some point but it did not do anything within my attention span.)
Why did you post this here instead of wherever you found the template?
Because I found the template years ago when I first installed home assistant and cant remember where I found it (and a search on the forum and google brought me here). I obviously made a mistake asking for help in this thread and apologize. I will remove my post if I can. Thanks for the assist.
likely somewhere in here:
Thanks for the helpful suggestion, i will check it out and see if i can find any info. Thanks again @finity
Does anybody know what category the Energy “integration” falls under on the Analytics webpage? I cannot find it as Energy.
