2021.4 - modbus - lovelace frozen - modbus broken?
When using the following modbus configuration loverlace is getting unreachable in a few minutes after starting up.
 modbus:
   - name: SMA
     type: tcp
     host: 192.168.15.35
     port: 502
This code is deprecated but seems to give issues right now.
I am trying to change the code to someting like:
modbus:
  - name: "SMA"
    type: tcp
    host: 192.168.15.35
    port: 502
    sensors:
      - name: "SMApwrL1"
        hub: SMA
        unit_of_measurement: kW
        slave: 3
        register: 30777
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 5
but getting errors when checking the config file:
nvalid config for [modbus]: [hub] is an invalid option for [modbus]. Check: modbus->modbus->0->sensors->0->hub. (See /config/configuration.yaml, line 81).
(line 81 is at line starting with: modbus:)
What is wrong with my code? This should be ok right?
As far as I can tell, the line “hub: SMA” in block
- name: "SMApwrL1"
        hub: SMA
should not be there.
However I myself have some problems with the nes mosbus sensor definiton, as after rewriting my config I cannot connect read my server.
Just went back to my old situation and changed the following:
 modbus:
   - name: "SMA"
This does not change the situation.
Modbus seems to be broken right now.
Ok have changed to the following in my configuration.yaml. This should be right, right? But still get: Invalid config for [modbus]: [register] is an invalid option for [modbus]. Check: modbus->modbus->0->sensors->0->register. (See /config/configuration.yaml, line 91).
modbus:
  - name: "SMA"
    type: tcp
    host: IP_ADDRESS
    port: 502
    sensors:
      - name: "SMApwrL1"
        slave: 3
        register: 30777
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 5
      - name: "SMApwrL2"
        slave: 3
        register: 30779
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 5
      - name: "SMApwrL3"
        slave: 3
        register: 30781
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 5
      - name: "SMAcurL1"
        unit_of_measurement: A
        slave: 3
        register: 30977
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 5
      - name: "SMAcurL2"
        slave: 3
        register: 30979
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 5
      - name: "SMAcurL3"
        slave: 3
        register: 30981
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 5
      - name: "SMAvoltL1"
        unit_of_measurement: V
        slave: 3
        register: 30783
        count: 2
        data_type: uint
        scale: 0.01
        precision: 1
        scan_interval: 5
      - name: "SMAvoltL2"
        slave: 3
        register: 30785
        count: 2
        data_type: uint
        scale: 0.01
        precision: 1
        scan_interval: 5
      - name: "SMAvoltL3"
        slave: 3
        register: 30787
        count: 2
        data_type: uint
        scale: 0.01
        precision: 1
        scan_interval: 5
      - name: "SMAnetHZ"
        unit_of_measurement: Hz
        slave: 3
        register: 30803
        count: 2
        data_type: uint
        scale: 0.01
        precision: 2
        scan_interval: 5
      - name: "SMApwr"
        slave: 3
        register: 30775
        count: 2
        data_type: int
        scale: 0.001
        precision: 2
        scan_interval: 5
      - name: "SMAtotal"
        unit_of_measurement: MW
        slave: 3
        register: 30529
        count: 2
        data_type: uint
        scale: 0.000001
        precision: 2
        scan_interval: 5
      - name: "SMAtoday"
        unit_of_measurement: kWh
        slave: 3
        register: 30535
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 5
      - name: "SMAtempinternal"
        slave: 3
        register: 34113
        count: 2
        data_type: uint
        scale: 0.1
        precision: 2
        scan_interval: 5
      - name: "SMAtempambient"
        slave: 3
        register: 34609
        count: 2
        data_type: uint
        scale: 0.1
        precision: 2
        scan_interval: 5
      - name: "SMAdevtype"
        slave: 3
        register: 30053
        count: 2
        data_type: int
        scan_interval: 5
      - name: "SMAgridrelay"
        slave: 3
        register: 30217
        count: 2
        data_type: int
        scan_interval: 5
      - name: "SMAderating"
        slave: 3
        register: 30219
        count: 2
        data_type: int
        scan_interval: 5
      - name: "SMAcondition"
        slave: 3
        register: 30201
        count: 2
        data_type: int
        scan_interval: 5
register is address in the new config
Thank you. That was a simple error :relaxed:
But after fixin this error, after a minute or so Lovelace is not responding anymore. I think there are issues with the new modbus implementation.
It should be working right wit the code below. Or am I overloading modbus some how with this scan interval and reading all these parameters?
modbus:
  - name: SMA
    type: tcp
    host: MY_IPADDRESS
    port: 502
    sensors:
      - name: SMApwrL1
        slave: 3
        address: 30777
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 15
      - name: SMApwrL2
        slave: 3
        address: 30779
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 15
      - name: SMApwrL3
        slave: 3
        address: 30781
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 15
      - name: SMAcurL1
        slave: 3
        address: 30977
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 15
      - name: SMAcurL2
        slave: 3
        address: 30979
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 15
      - name: SMAcurL3
        slave: 3
        address: 30981
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 15
      - name: SMAvoltL1
        slave: 3
        address: 30783
        count: 2
        data_type: uint
        scale: 0.01
        precision: 1
        scan_interval: 15
      - name: SMAvoltL2
        slave: 3
        address: 30785
        count: 2
        data_type: uint
        scale: 0.01
        precision: 1
        scan_interval: 15
      - name: SMAvoltL3
        slave: 3
        address: 30787
        count: 2
        data_type: uint
        scale: 0.01
        precision: 1
        scan_interval: 15
      - name: SMAnetHZ
        slave: 3
        address: 30803
        count: 2
        data_type: uint
        scale: 0.01
        precision: 2
        scan_interval: 15
      - name: SMApwr
        slave: 3
        address: 30775
        count: 2
        data_type: int
        scale: 0.001
        precision: 2
        scan_interval: 15
      - name: SMAtotal
        slave: 3
        address: 30529
        count: 2
        data_type: uint
        scale: 0.000001
        precision: 2
        scan_interval: 15
      - name: SMAtoday
        slave: 3
        address: 30535
        count: 2
        data_type: uint
        scale: 0.001
        precision: 2
        scan_interval: 15
      - name: SMAtempinternal
        slave: 3
        address: 34113
        count: 2
        data_type: uint
        scale: 0.1
        precision: 2
        scan_interval: 15
      - name: SMAtempambient
        slave: 3
        address: 34609
        count: 2
        data_type: uint
        scale: 0.1
        precision: 2
        scan_interval: 15
      - name: SMAdevtype
        slave: 3
        address: 30053
        count: 2
        data_type: int
        scan_interval: 15
      - name: SMAgridrelay
        slave: 3
        address: 30217
        count: 2
        data_type: int
        scan_interval: 15
      - name: SMAderating
        slave: 3
        address: 30219
        count: 2
        data_type: int
        scan_interval: 15
      - name: SMAcondition
        slave: 3
        address: 30201
        count: 2
        data_type: int
        scan_interval: 15
I have the same problem. Is there any solution?
After installing 2021.4.6 modbus with the new syntax works for me again.
Seems to be again broken in 2021.5.2
Lovelace freezes short after startup. No Problem if i disable ModBus serial RTU with 2021.5.2
There have been some fixes with 2021.5/2021.5.1/2021.5.2 but they will freeze HA if you use at least serial modbus, havn’T tested with modbuy via tcp.
I reverted to 2021.4.6 as Modbus serial will work with this.
Same issue for me. When I switch modbus device to TCP , HA freeze and no respond at all.No logs now error…just freez
Same issue here for me for ModBus RTU, I was wondering what was going wrong, now I know… Lovelace is frozen.
