After reading the breaking changes, I am still very confused on how to fix my problem.
When doing a config Validation I get the following
Platform error sensor.version - cannot import name ‘HaVersion’ from ‘pyhaversion’ (/usr/local/lib/python3.8/site-packages/pyhaversion/init.py)
I saw the Custom integrations: Version warning in the blog post but I am at a total loss on how to fix it.
Can someone point me in the right direction.
Thanks so much.
In my sensor.yaml file (or configuration.yaml if that’s where your sensors are) I just commented out any sensor using the version platform (put # before the line in your config files), then restarted HA, once rebooted I added back the sensors (remove # in yaml) and rebooted. All working fine after that.
You most likely have a custom integration that requests an older version of pyhaversion, I’m taking a guess that it’s the breaking_changes custom integration, if so update it, if no look at the manifest.json file of your other custom integrations.
It is the breaking changes file. I deleted it from HACS and my config.yaml, but check config still gives me the error. It feels like I am in a loop. Is there another way to clear it out to restart safely.
