2021.5: Stability, performance, triggers, color modes!
I think it fails on the SSL-sertificate.
To make it work you have to have ssl: false in your motionEye addon config.
You also have to set a port to your web-interface in the same place.
Then use http://ip:port in the integration configuration. You can also use the hostname (a0d7b954-motioneye) here.
I found that it gives an error if you have blank passwords, so you should probably make them.
I never told you to remove it. I wasn’t even talking to you. I was talking to the people who use Fritz box. You you and Others decided to bring me into a deprecation argument. Do whatever you wanna do, I don’t care.
@ben1410 Switching to the template function approach does indeed “resolve” the issue and is the preferred syntax anyway, see warning here: Templating - Home Assistant
Since I’m looking to do something similar, can I ask what may be a dumb question?
Can I translate a legacy template:
wan:
   friendly_name: "Internet Connection"
   value_template: "{% if is_state('binary_sensor.WAN_Check_BBC', 'off') and is_state('binary_sensor.WAN_Check_OpenDNS', 'off') %}Offline{% else %}Online{% endif %}"
to modern:
- name: wan
  state: "{% if is_state('binary_sensor.WAN_Check_BBC', 'off') and is_state('binary_sensor.WAN_Check_OpenDNS', 'off') %}Offline{% else %}Online{% endif %}"
retaining the friendly name for display use? or do I need to factor display name choices into migrating?
Is this needed, legacy not supported anymore?
No I believe it’s still supported - I just like the idea of centralising my template sensors as I have a lot of them.
However I cannot see friendly_name detailed under the ‘modern configuration’ section of the integration documents - which will add a multiplier to the time required to shift my configuration around.
To have it decoupled from HA. Like a ZHA docker container instead.
You mean like using zigbee2mqtt?
Exactly. Not sure why anybody is confused. I think some are confusing deprecating something with decommissioning something.
Yes but zha is not zigbee2mqtt. I like the way it works with the zwavejsmqtt container which has the option to enable a websocket link to ha instead of mqtt.
38 posts were split to a new topic: Migrating legacy templates to the new template section
I have not, will do. I have an AVR-X3000.
Ah , i have 4000, it’s the same… Ok, gonna wait then for update… Can you report?
Integration setup times in info panel are very useful. How about sorting by them?
I’m not sure where to report, and I won’t be able to do it before getting home tonight (it’s 8:37 AM now here). Would you mind doing it?
Thanks a lot.
Tales
yes this is really cool. But how to actually achieve this :slight_smile: is there a guide on this I have missed.?
On GitHub, create an issue there… i havent updated yet, so I cant
Do not update if you have MS SQL database or else :slight_smile: you will get in trouble…
Any ideas for me?
E.g. (no changes with this release, done in one of the last releases, but just as an example) callmonitor, before: a lot of options in config.yaml. Now since some time in UI. Changes in documentations here:
If there are now changes in host, port, id, user, pw, options, … everything could be adjusted in yaml. And How to do it now? There are no options in this integration. And there are no options in most of the ofter integrations I use, which were moved from yamlt to UI. Perhaps the setup is moved now, but how to adjust if needed?
I have the same issue with the Lovelace control cards for Tasmota lights being broken (both for lights configured with MQTT integration and those configured with the Tasmota integration).
The issue was logged in detail as a bug during development:
but then it looks like it was just closed and ignored without being fixed in the PR:
Further, the reason given for implementing the breaking change:
Tasmota lights no longer supports deprecated white_value, use rgbw_color instead.
does not seem to be mentioned anywhere in the Tasmota changelogs:
(and I have tested that setting a value for ‘white’ still works fine for Tasmota lights, whether from the Tasmota console or MQTT, including for the latest 9.4.0.3 Tasmota release.)
So there certainly seems to be something odd going on here.
@emontnemery could you please take a look at this, including the bug report issue #50095 (linked above).
