Yes but zha is not zigbee2mqtt. I like the way it works with the zwavejsmqtt container which has the option to enable a websocket link to ha instead of mqtt.
38 posts were split to a new topic: Migrating legacy templates to the new template section
I have not, will do. I have an AVR-X3000.
Ah , i have 4000, it’s the same… Ok, gonna wait then for update… Can you report?
Integration setup times in info panel are very useful. How about sorting by them?
I’m not sure where to report, and I won’t be able to do it before getting home tonight (it’s 8:37 AM now here). Would you mind doing it?
Thanks a lot.
Tales
yes this is really cool. But how to actually achieve this
is there a guide on this I have missed.?
On GitHub, create an issue there… i havent updated yet, so I cant
Do not update if you have MS SQL database or else
you will get in trouble…
Any ideas for me?
E.g. (no changes with this release, done in one of the last releases, but just as an example) callmonitor, before: a lot of options in config.yaml. Now since some time in UI. Changes in documentations here:
If there are now changes in host, port, id, user, pw, options, … everything could be adjusted in yaml. And How to do it now? There are no options in this integration. And there are no options in most of the ofter integrations I use, which were moved from yamlt to UI. Perhaps the setup is moved now, but how to adjust if needed?
I have the same issue with the Lovelace control cards for Tasmota lights being broken (both for lights configured with MQTT integration and those configured with the Tasmota integration).
The issue was logged in detail as a bug during development:
but then it looks like it was just closed and ignored without being fixed in the PR:
Further, the reason given for implementing the breaking change:
Tasmota lights no longer supports deprecated white_value, use rgbw_color instead.
does not seem to be mentioned anywhere in the Tasmota changelogs:
(and I have tested that setting a value for ‘white’ still works fine for Tasmota lights, whether from the Tasmota console or MQTT, including for the latest 9.4.0.3 Tasmota release.)
So there certainly seems to be something odd going on here.
@emontnemery could you please take a look at this, including the bug report issue #50095 (linked above).
Yeah I’d assumed that after reading the documentation hence the “dumb question” comment in my post, but thanks for confirming - I didn’t want to make a massive set of changes based on my reading comprehension alone.
I should be able to workaround keeping the previous object id (e.g. sensor.wan in my example) which prevents me redoing some composite sensors, automation references etc. with some judicious titling and tooltipping in Lovelace.
Were there any breaking changes to zwavejs like zwave_js_value_notification events? I am not getting any events on minimote button press whereas i can see it in the log on zwavejs2mqtt.
denonavr users, i reported the issue :
Hello ! I’ve got the same error
What do you mean by “rebuild zwavejs2mqtt” ?
Thanks !
HI,
anyone can help me here
21-05-06 13:11:52 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.5.0
21-05-06 13:11:52 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.5.0.
21-05-06 13:11:54 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.5.0 -> 500 Server Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi4-64-homeassistant:2021.5.0/json: Internal Server Error ("readlink /mnt/data/docker/overlay2: invalid argument").
21-05-06 13:11:54 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant
I started from a fresh imagine, but it doens’t work
I get the same 2 error message every 10 seconds since update. I don’t have a clue where even to look, can someone give me an idea?
2021-05-06 15:21:30 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
TypeError: 'NoneType' object is not callable
I dont know how you installed zwavejsqmqtt, was it via npm or from git?
Hello guys, did anyone have tried to configure the new integration for the iAlarm alarm system?
I have the the XR main unit from Antifurto365.
My HA instance is on the same layer-2 network as the alarm unit and I can ping it from HA with no problem at all.
I get only this for a Move:
2021-05-06 15:48:39 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/sonos/speaker.py", line 261, in async_update_device_properties
await self.async_update_battery_info(battery_dict)
File "/usr/src/homeassistant/homeassistant/components/sonos/speaker.py", line 270, in async_update_battery_info
if is_charging == self.charging:
File "/usr/src/homeassistant/homeassistant/components/sonos/speaker.py", line 289, in charging
return self.power_source != "BATTERY"
File "/usr/src/homeassistant/homeassistant/components/sonos/speaker.py", line 284, in power_source
return self.battery_info["PowerSource"]
TypeError: 'NoneType' object is not subscriptable
Anyone with the same problem or any advice?
