Tbh your default Themes question is like asking Microsoft why they don’t have a dark mode for excel… theres probably no reason and no one here is going to know the answer.
As for your service question, you answered it yourself. You didn’t find the service to turn on or off polling cause it doesn’t exist. You can control all of that yourself by turning off polling and updating the sensor using an automation.
Iirc that’s a bug in a custom card, can’t remember which one is causing it. Just update all your custom cards and it should be fixed. I think it’s the secondary entity row or template row?
Erm…, I pointed to the issue which includes the link to the maintained fork you linked then. So you pointed to the thing I pointed, too. At least when you read the issue-thread. I didn’t pointed or said anything about patching the local code. So…?
Several times I tried to upgrade, but I always get these errors
21-06-05 20:21:27 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2021.6.2
21-06-05 20:21:27 INFO (SyncWorker_5) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-64-homeassistant:2021.4.6 to homeassistant/raspberrypi3-64-homeassistant:2021.6.2
21-06-05 20:21:27 INFO (SyncWorker_5) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-64-homeassistant with tag 2021.6.2.
21-06-05 20:21:33 ERROR (SyncWorker_5) [supervisor.docker.interface] Can't install homeassistant/raspberrypi3-64-homeassistant:2021.6.2: 404 Client Error for http+docker://localhost/v1.40/images/homeassistant/raspberrypi3-64-homeassistant:2021.6.2/json: Not Found ("no such image: homeassistant/raspberrypi3-64-homeassistant:2021.6.2: No such image: homeassistant/raspberrypi3-64-homeassistant:2021.6.2")
21-06-05 20:21:33 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
Before I had issues with upgrading from 2021.5.4 to 2021.5.5 and I needed to do a fresh Hass setup and to restore an older backup. Now I have a working older version but I can’t upgrade.
Is it possible that the supervisor is downloading the image on one place and tries to use from another place? Could there be an issue that my former install was 32 bit, current fresh install was 64 bit, but the restored backup was from the 32 bit installation?
