I’ve removed all references to Buienradar from Yaml afaik, rebooted a couple of times, removed the integration and re-added it. But no joy yet. Any tips?
Sorry, i did search around but missed that. Thank you: works. Not sure if i missed it, but would be great to stress this during config of that integration.
Yes, agree. I use homeassistant for a very long period and have LOADS of integrations and this was the first time I had to do this. It is easily missed.
Hm. Did not get this. In MS I can select the themes. Here in HA there is the theme available, but not selectable. To be sure to talk about the same thing.
In User-setting, I can select the default theme:
But in a view or card or … I cannot set/select/assign the default skin, but only custom ones:
How to assign the default skin there? Perhaps I miss the easiest step for this.
O.k. Thanks! Thought I only didn’t find this, because I thought that it is available to have e.g. only two event/automation-call to enable/disable instead of having thousands calls every x seconds with recurring automations. But perhaps it is internally the same load with both options.
Same for me on a Pi3b with HassOS. 2021.6.2 does not install via web UI nor CLI. I did a “core update --version 2021.6.1” in CLI and that worked coming from 2021.5.5.
I never complained, I was just talking about windows logs. I only complain about users loudly to my wife. Checking the logs will always be an issue, and the unfortunate truth is that the software is small enough that it will always be the norm to check the logs. That’s what I was trying to imply with my post.
The 3 softwares I deal with on windows force me to be in eventviewer constantly when things go wrong on the manufacturing line
What happens with EcoWitt integrations?
Just updated from 2021.5.1 to 2021.6.2 and got the information, that the Ecowitt integration is no longer available. How to solve this?
Thanks - Dave
