2021.6: A little bit of everything
Thank you … I will update the custom component and try again. For Tahoma integration failing to load, which is the solution?
No clue… “Working bad” isn’t really a starting point for support :wink:
He wrote “not working Tahoma component is definitely bad”.
You guys are second to none in regards of help and support.
@LSD70 check the version of Somfy Tahoma integration installed in your system. By the first glance on Github, most recent version is compliant with recent HA requirements. If it’s not version problem, check HA logs
Thanks Maxyn, I have checked and indeed my tahoma component needs update (no version is indicated in the manifest). I will install the latest version and try to upgrade to Core 2021.06.03.
Get off your high horse. I help 10x more people than most and have numbers to back it up. Im not obligated to help everyone, especially when I’ve never used the integration.
I am confused, are you not talking about the built in tahoma integration? Tahoma - Home Assistant
If not, please tell us what you are using, and please use the skills you learned here How to help us help you - or How to ask a good question
I am also a bit confused now. I believe my configuration is linked now to a tahoma custom component I was using when the built in integration was not there yet. I tried to add now to my configuration.yaml the built in integration, but for some reason, the system is still using the custom components. So I would say that I am using the custom compoent (GitHub - iMicknl/ha-tahoma: Custom component for Home Assistant to interact with smart devices via Somfy TaHoma or other OverKiz based API's.) that by the way is working fine.
I’m able to set up the http component to work well with traefik, this issue seems to be that when I define my traefik IP as a trusted_proxies it now warns me when 127.0.0.1 (Nabu Casa remote UI) connects, and the documentation for Nabu Casa states that they are
…currently not forwarding the IP address of the incoming request
and
Because of this, we are unable to support Home Assistant instances that have configured 127.0.0.1 or ::1
Collapsed Attributes Problem
Well, this has been ill-conceived. Now, we have the problem that for all language we see the English word “Attributes” with the more-info-card. You might say, that is not your problem, however, I would like to have the choice to either jump to the new format or keep the old one.
grafik
Hacs stopped loading and sub configs such as sonoff/alex
I noticed when I upgrade to 2021.6 a week ago, my frontend cards got rearranged. This has never happened for any upgrades I have done in the past. I am going to wait for a few more updates before manually moving them back to my liking.
Working well here.
My scene controller no longer works after upgrading. Seems like there is an issue with the cooper_controllers integration. I see this in the logs:
Setup failed for cooper_controllers: Integration not found.
Sounds like your using a custom integration that now doesn’t meet the requirements to have a version.
check to see if its been updated, failing that add it yourself, rea further up about how to fix manually
Have you read this thread?
Thanks, figured it out and submitted my first pull request to Github!
Random: I just want to say the little things count. Here’s my little example:
24 hour time format configurable in user profile :slight_smile:
It just makes figuring out when things happened easier when you need to compare timestamps.
Thank you!!
Now situation with Companion App become even more strange. I cannot display any history graphs in history view nor using build in history card. All are empty. All other types of graphs (mini graph card or ApexChart) work without problems. Problem is only related to mobile app, in the browser or Companion App on Mac there are no problems with these graphs.
Not sure if this is related, but now I started to receive tons of errors in log, every time I try to refresh page containing these graph in app:
2021-06-12 08:23:32 ERROR (MainThread) [frontend.js.latest.202106030] http://192.168.52.53:8123/frontend_latest/chunk.820b4f10c06bebb7d0bb.js:142:9782 TypeError: undefined is not an object (evaluating 'this._chart.chartArea.top')
2021-06-12 08:23:32 ERROR (MainThread) [frontend.js.latest.202106030] http://192.168.52.53:8123/frontend_latest/chunk.8062800ced073df0c76f.js:2:117721 TypeError: null is not an object (evaluating 't.parentNode')
This repeats multiple time, but with different numbers after frontend_latest/chunk.
Am I alone?
after upgrading to core-2021.6.4 there’s an issue with Denon AVR integration , I have to roll back to core-2021.6.3.
I second that. Denon integration broken here too. I will make a issue on GitHub, after collecting needed info i will rollback too… :frowning:
