I digress.
You know what it is with the US and international standards, right?
Itâs only been 35 years that ISO decided that Monday is the first day of week, and itâs only been 6 months that I opened an issue for this
Calendars traditionally show Sunday as the first day of the week. As far as I am concerned that is correct.
Not in the most of Europe
Well, itâs not an issue itâs a #feature-requests.
vue2-daterange-picker built into ha is not using locale-data.
https://innologica.github.io/vue2-daterange-picker/#props
A system would need to be put in place for it to be used.
In the US maybe, but for all of Europe, not so much
Maybe in the Anglo-saxon world at large, then but ISO 8601 univocally set the first day of week to Monday.
OK.
Now, whether asking for this datetime picker to follow the locale like everywhere else is a bug report of a feature requestâŚ
And, once again, the fallback if locale is not implemented should be ISO rather than the anglo-saxon way
Then you should take taht up with the creators of vue2-daterange-picker as they set the default for that resource
Just so we are clear here: We donât use locale at all in that element. Itâs using the defaults for that package, which is not managed by HA. Everything about this is a Feature Requests, even changing the default because it would require HA to use locale-data
. You know enough about this to know this without being a sarcastic.
Not quite fair point. The 24h is overridden.
Itâs a one-liner in HA to follow the international convention:
props: {
"time-picker": true,
"locale-data": "{ firstDay: 1}",
or similarâŚ
Thatâs still not a bug. Itâs a #feature-requests. And I can guarantee you they wouldnât change the defaults without implementing a whole locale based system because weâd just be in the same situation but in reverse.
Not on this side of the pond.
No. Iâll stop trolling, but standard in Monday, not Sunday. Punt.
Is it a coincidence that the 24h setting is locale-based while itâs default is 24H, not AM/PM? Allow me to wonder
What does that have to do with anything? I thought you werenât trolling anymore?
Itâs a reference to your âfeature requestâ vs. âbugâ argument
There is no argument here. Iâm simply telling you why action hasnât been taken. A system would need to be built to handle locale. It would need a UI override option and a property to hold the data based on the default, locale, or user override. It falls into #feature-requests.
Donât we have that already for units?
Yes, but itâs specific to Time Format. It could be tied to that, but again⌠itâs a #feature-requests. The Time Format has never been intended to change the first day of the week.
Iâd expect a separate profile item Date Format
that would change the date & the number of the week. However Iâm not 100% sure if there are locales that use sunday as the first, iso date, and 12 hr time format. If thatâs a possibility, youâd need another user profile item for first day of the week.
Personal preference probably comes into it too. I just had a look at Google Calendar, it offers Saturday, Sunday and Monday as options to start the week. A select with those options (so not tied to locale) would probably suit everyone.
