2021.6.x and iOS 12.5.3 - lovelace continually refreshing
Since upgrade to 2021.6 my wall-mounted iPad (running iOS 12.5.3) is continually refreshing. This is happening every 30-45s. Is anyone else experiencing this?
Not in these short time patterns but: yes (iPadOS 14.6). Quite annoying if you’re just editing code.
Hi Juggler, Have the same problem, Is updating a lot. And, then for long periods it is not updating at all, hence changes are not visible on the screen. Need to swipe down on the screen to get a response.
I tried on my iPad Pro running latest IOS version. No problems at all, however it is my old iPad I use for dashboard
If you find a solution I will be deligthed to know.
Same problem here, since updating to HA 2021.6.6 my iPad Air on iOS 12.5.4 will refresh the dashboard every 10-20s. Both in app and in browser window. After some time the app eventually freezes and I have to quit the app and reopen it… just so it can start the same routine all over again.
All I now have is a wall mounted iPad with the screen off. Nice.
This should be fixed in the next release of HA. Use ES5 build for Safari 12 and below by bramkragten · Pull Request #9482 · home-assistant/frontend · GitHub
Any word on whether this is fixed yet? I’m experiencing terrible refreshes on my iPad Mini 2s if I update HA Core to anything above 2021.5.5
I am wondering the same thing. Just installed the app on my gen 4 iPad Air and I notice that it cannot stay on the Lovelace page I have active for more than about 5-10 minutes before refreshing and going to the first, overview page. It’s quite annoying.
