2021.7.0 Breaks Google Assistant Integration
After installing core-2021.7.0 (as well as 2021.7.1) the Google Assistant Integration no longer works. All commands to the Google device reponds with cannot connect to the “xxxxx” application where “xxxxx” is the name of the Google Project. I should note that this is a manual setup of Google Assistant, not through Home Assistant Cloud.
Are you running Nginx? Did you read the breaking change about proxies?
Sorry, I missed that. Will look into it and see if that fixes the problem. And thank you very much!
it should, I had the same issues when I upgraded. You just need to configure the IP for the nginx add-on. If you check your logs, you should see complaints about an IP that’s not a trusted proxy. Just use that IP in your configuration.
That took care of the problem, thanks again!
