2021-07-07 16:17:02 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/fritz/common.py", line 218, in scan_devices
self._devices[dev_mac].update(dev_info, dev_home, consider_home)
File "/usr/src/homeassistant/homeassistant/components/fritz/common.py", line 276, in update
consider_home_evaluated = (
TypeError: '<' not supported between instances of 'float' and 'datetime.timedelta'
@arganto which environment are you using ? Because you miss a requirements for fritz.
Such library, fritzprofiles, has been updated recently and is part of both the manifest of the integration and the requirements.txt of HA core.
Setup failed for google_assistant: Unable to import component: No module named 'av'
Setup failed for camera: Unable to import component: No module named 'av'
Setup failed for mobile_app: Unable to import component: No module named 'av'
also homekit integration no longer works
Invalid config
The following integrations and platforms could not be set up:
- cloud
- camera
- homekit
Please check your config and logs.
I had a simular issue ( cloud and camera failed due to missing modules: libswscale, libavfilter and libavdevice). I solved it by installing the libs. I am running HA core in virtualenv on Ubuntu.
unfortunately i don’t have time for that. i downgraded for now. i can DM you the .homeassistant folder but i’ve got no time to fill issues and templates.
it seems that i’m not the only one with these problems so it should be easy to reproduce
Great news for the Yamaha MusicCast integration. Is there somewhere more details about how it works, which services can now be used in automations, especially for the grouping function?
Update: the workaround is to go to the integrations page, click configure on the fritz integration and simply save it. It just does seem to use the wrong type if there is no config.
