Running core in docker on Unraid
dropped back to
homeassistant/home-assistant:2021.6.5 it now works
homeassistant/home-assistant:2021.7.1 does not
Error below
Logger: homeassistant.setup
Source: components/rainbird/init.py:4
First occurred: 2:52:04 PM (1 occurrences)
Last logged: 2:52:04 PM
Setup failed for rainbird: unknown error
File “/usr/src/homeassistant/homeassistant/setup.py”, line 201, in _async_setup_component
component = integration.get_component()
File “/usr/src/homeassistant/homeassistant/loader.py”, line 490, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File “/usr/local/lib/python3.9/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1030, in _gcd_import
File “”, line 1007, in _find_and_load
File “”, line 986, in _find_and_load_unlocked
File “”, line 680, in _load_unlocked
File “”, line 855, in exec_module
File “”, line 228, in _call_with_frames_removed
File “/usr/src/homeassistant/homeassistant/components/rainbird/init.py”, line 4, in
from pyrainbird import RainbirdController
File “/usr/local/lib/python3.9/site-packages/pyrainbird/init.py”, line 14, in
from pyrainbird.resources import RAIBIRD_COMMANDS
File “/usr/local/lib/python3.9/site-packages/pyrainbird/resources/init.py”, line 6, in
RAIBIRD_COMMANDS = json.loads(resource_string(‘pyrainbird.resources’, ‘sipcommands.json’).decode(“UTF-8”),
File “/usr/local/lib/python3.9/json/init.py”, line 359, in loads
return cls(**kw).decode(s)
TypeError: init() got an unexpected keyword argument ‘encoding’
