This doesn’t work as I expected, as I found out when I woke up to a cold hot water tank this morning. I created a couple of test automations to check the behaviour:
- alias: Test on
- platform: numeric_state
entity_id: input_number.test_sensor
below: input_number.test_threshold
- service: homeassistant.turn_on
entity_id: input_boolean.test_trigger
- alias: Test off
above: input_number.test_threshold
- service: homeassistant.turn_off
and a card:
The trigger fires as expected when the sensor value changes to cross the threshold value, but if it’s the threshold value that moves, the trigger doesn’t fire.
This seems a bit pointless to me — was that the intended behaviour? I’ve reverted to a template trigger on my hot water automation.
It’s not that they would be ignored, but it’s not either that altering it should trigger the automation.
Next time the actual trigger is activated, i.e. the next time the state changes, the latest value will be used
If that is the intent, it should be made crystal-clear in the documentation. People get confused all the time about numeric_state only firing if the entity crosses the static threshold — this change makes it even more confusing as the values cross (“moving the goalposts”) but the trigger doesn’t fire.
Yep I noted the same thing when helpers were introduced for conditions. Made a post that I cant find. Even mentioned it in the beta release but got no response. I went back to using templates.
EDIT: I remembered incorrectly, this was about triggers.
Thanks. I’m not so sure it is an edge case, as it suggests two values can be reliably compared. In my application, I monitor the “state of charge” of my hot water tank, and have a “target” schedule to decide when the boiler should run.
I had ass-u-med that using the target as the above/below would work, triggering when I adjusted the target up to above the current status. It doesn’t, though, so back to templates here too for now.
It seems that a listener should be created for all entities involved. If not, seems pretty useless IMO. Might be a harder change than normal though. Either way, a issue is a good first step.
