English please.
You need kWh entites not W. You can use this integration to convert W to kWh:
Companion app working here.
Hi, thank you for replying. I have a kWh entry, have you seen the bottom screenshot? any other tip?
You don’t have the required attributes.
Yep, that’s what I ended up doing. Next time I should check if I’m complaining about a 3rd party integration or not first too!
That’s helpfull? What attributes do I need? What do I mis where?
Thanks for this. Where is this documented? I could not find that in the referred documentation?
Sorry to bother again (3rd strike haha ):
I’m still stuck with the cost entity not showing up (2021.8.0: Feel the energy - #271 by e-raser).
Can anyone point me to the right direction? Maybe @tom_l ? I have a manual total cost entity I would like to select but it doesn´t show up, although it has all the needed attributes and I´ve really read all documentation available twice meanwhile
Except last_reset
There is a new cost entity that is automatically created when you enable the new Energy feature.
Check Developer Tools/Entities to see its name ( eg sensor.xxxxx_cost) and add it to your recorder section in your config file.
What Nick says, but also: do you Record the entities?
Btw, anyone seeing Co2 and Forecast.solar? Both are unavailable right now ?
neither is available here either
I have the same problem. Any news ?
Don’t ask in more than one thread please.
same problem, had it all working but it stopped after a recent update.
