Hi, I’m using a battery nest doorbell via nest integration and i can’t find a way to get an url of the mp4 clip saved in nest folder to use it in an automation. I can see the events in media sources but that requires an authSig. Is this possible ?
See the examples in Google Nest - Home Assistant – yes, getting the media clips involves authentication so that you can’t steal them.
I read the documentation, notifications in companion app is working as expected but what i want is to send the notification to pipup app running on my shield tv and the json is expecting the full url to the media clip and i have no idea how to generate the url with authentication.
The integration or auth mechanism needs to support this (e.g. a home assistant auth token, or the right authentication in the url), so if it doesn’t then you can’t do it.
Thanks for clarification.
You added it just now? I thought it wasn’t possible anymore?
Might be an old post but still helpful into 2023/24, thanks!!
