How do we disable the health check?
The Health Check page only speaks of it being enabled by default, and how to enable it if not using default_config:
comes with a disclaimer
Latest release 2022.10.5 broke my plugwise integrationā¦
File "/usr/src/homeassistant/homeassistant/components/plugwise/gateway.py", line 44, in async_setup_entry_gw
connected = await api.connect()
File "/usr/local/lib/python3.10/site-packages/plugwise/smile.py", line 296, in connect
result = await self._request(DOMAIN_OBJECTS)
File "/usr/local/lib/python3.10/site-packages/plugwise/helper.py", line 304, in _request
return await self._request(command, retry - 1)
File "/usr/local/lib/python3.10/site-packages/plugwise/helper.py", line 301, in _request
raise ConnectionFailedError(
plugwise.exceptions.ConnectionFailedError: Plugwise connection error, check log for more info.
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 365, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/plugwise/__init__.py", line 13, in async_setup_entry
return await async_setup_entry_gw(hass, entry)
File "/usr/src/homeassistant/homeassistant/components/plugwise/gateway.py", line 50, in async_setup_entry_gw
f"Error while communicating to device {api.smile_name}"
AttributeError: 'Smile' object has no attribute 'smile_name'
That error says it canāt connect. Check your connection first
Have problem with the lovelace after restart or opened it in browser. My 2 tablet and on my pc too when boot up or open it the lovelace sometime not load correctly. Mixed the things on the dashboard. Sometimes must do 1 or 2 refresh and after good again.
Before not have this problem. 1-2 months ago see this problem first. What happend after HA update and how can I solve it? Cleared cache, but not solved it.
same problem
even made a ticket, but now i suspect the manufacturer
maybe an intentional bug in the firmware, for people who donāt use their ecosystem
Could be, Iāve been waiting for someone else to run into this issue as well. Personally, I really donāt like these V2s and Iāll be avoiding them in the future. Not one change on these devices made them better. All regressions.
for me it was the only one available as the LYWSDCGQ were no more available
love those, have 4 of them running, including one outside
i guess xiomi doesnāt like people buying their devices but not their ecosystem
Yeah, apparently there are other brands that are similar to the old one. Not sure if you can buy them anymore.
buying nowadays is mostly a game of chance. noone is advertising the fact you need a bind key
Done, and you where right! it seems to struggle with weak Wifi. Fixed by wired network now
Interestingly immediately after updating to 2022.10, all those entities from the official (!) shelly integration are gone:
button.devicename_ota_update
binary_sensor.devicename_firmware_update
I searched whole Issues Ā· home-assistant/core Ā· GitHub without a finding.
Looking at this topic it seems this never came up for othersā¦ very strange.
After restarting HA Core several times, restarting the shelly devices, reloading the shelly integrationā¦ Iām out of ideas.
Anyone who can helpā Have those entities been removed (silently)?
Iām updating to the next core release (2022.11) shortly and the latest (2022.12) within the next days as last hopeā¦
Update:
Solved @ Shelly: Firmware specific binary_sensor and button entities unavailable once updated to HA 2022.10 Ā· Issue #84877 Ā· home-assistant/core Ā· GitHub
