2022.10 core update broke automations
No solution:
Logger: homeassistant.helpers.check_config
Source: config.py:472
First occurred: 10:29:57 (2 occurrences)
Last logged: 10:33:04
Unexpected error validating config
  File "/usr/src/homeassistant/homeassistant/components/device_automation/action.py", line 61, in async_validate_action_config
    return cast(ConfigType, platform.ACTION_SCHEMA(config))
  File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 433, in validate_mapping
    raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: extra keys not allowed @ data['service']
  File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 113, in _try_async_validate_config_item
    validated_config = await async_validate_config_item(hass, config, full_config)
  File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 89, in async_validate_config_item
    config[CONF_ACTION] = await script.async_validate_actions_config(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 259, in async_validate_actions_config
    return await asyncio.gather(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 274, in async_validate_action_config
    config = await device_action.async_validate_action_config(hass, config)
  File "/usr/src/homeassistant/homeassistant/components/device_automation/action.py", line 63, in async_validate_action_config
    raise vol.Invalid("invalid action configuration: " + str(err)) from err
voluptuous.error.Invalid: invalid action configuration: extra keys not allowed @ data['service']
  File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 162, in async_check_ha_config_file
    await config_validator.async_validate_config(hass, config)
  File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 136, in async_validate_config
  File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 120, in _try_async_validate_config_item
    async_log_exception(ex, DOMAIN, full_config or config, hass)
  File "/usr/src/homeassistant/homeassistant/config.py", line 454, in async_log_exception
    message, is_friendly = _format_config_error(ex, domain, config, link)
  File "/usr/src/homeassistant/homeassistant/config.py", line 472, in _format_config_error
    f"[{ex.path[-1]}] is an invalid option for [{domain}]. "
IndexError: list index out of range
Hello , i have the same problem .
I’m restoring the 2022.9.7 core backup to.
Any solution ?
Should be fixed with 2022.10.2
I needed to comment the mqtt trigger on my zigbee2mqtt.yaml. The problem was this:
  - id: "zigbee2mqtt_create_notification_on_successfull_interview"
    alias: Zigbee Device Joined Notification
      platform: mqtt
      topic: 'zigbee2mqtt/bridge/log'
    condition:
      condition: template
      value_template: '{{trigger.payload_json.type == "pairing" and trigger.payload_json.message == "interview_successful"}}'
      - service: persistent_notification.create
        data_template:
          title: Device joined the Zigbee2MQTT network
          message: "Name: {{trigger.payload_json.meta.friendly_name}},
                    Vendor: {{trigger.payload_json.meta.vendor}},
                    Description: {{trigger.payload_json.meta.description}}"
After commenting this part out the automations loaded but all my zigbee devices were unavaliable. I think they seem to have disabled mqtt triggers, which the zigbee2mqtt integration needs. If this is the case and is with intent 2022.10 afterwards zigbee2mqtt is not supported anymore.
This is a fairly significant problem that I suspect is affecting quite a few installs. Does it need to be reported in a different place, such as the Core Issues tracker… Issues · home-assistant/core · GitHub
Has anyone installed 2022.10.2? I had so much trouble with the Restore and will not do it again.
Does the update work now?
This weekend I tried to fix every automation trying to change the triggers according to the errors (eg. not using device trigger but state trigger, rewrite all the automations that use the netatmo camera, etc) and I managed to get 2022.10.1 to work. Today I updated to 2022.10.2 and it’s still working but it was very time consuming.
So I don’t know if 2022.10.2 fixed something or not
Do you have zigbee2mqtt?
Yes 77 ZigBee devices recently migrated from deconz to ZigBee2mqtt but since I had to migrate all the sensors I already fixed the automations before migrating using the state trigger and not device trigger in that way I had to rewrite only the automations for ZigBee buttons.
ZigBee2mqtt never was an issue with 2022.10 core update for me
Is that really the intention of HA to only use state triggers instead of device triggers? Normally it should be possible to use all triggers which are available in the drop down. Otherwise the drop down makes no sense for me or should be limited only to triggers which work.
You are right but I was looking for a straight forward way to migrate from a controller (and ZigBee platform) to another and for a way to not have to fix a lot of automations every time I need to change my ZigBee network.
I found that using state trigger and models condition the 99% of my automation is still functional if during the network repair I maintain the same names between sensors.
I preferred to rewrite all my automations (where possible) with that on mind.
The automations that were giving me issues with the update were related to the “trigger device” used with the netatmo platform in the automations. I changed them with trigger state when I was on 2022.9.7 than updated to 2022.10.1 and no more automations errors for me…
I’ve updated to 2022.10.2 and I’m no longer getting the problem I was having
Update worked also now on my side without issues!
2022.10.2 seems to have resolved this issue for me.
