I’ve just updated the core to 2022.10 from 2022.9.7, as soon as the update finished I had the following error:
Logger: homeassistant.config
Source: components/device_automation/trigger.py:69
First occurred: 08:34:07 (1 occurrences)
Last logged: 08:34:07
Invalid config for [automation]: invalid trigger configuration (See /config/configuration.yaml, line 10).
File "/usr/src/homeassistant/homeassistant/components/device_automation/trigger.py", line 67, in async_validate_trigger_config
return await platform.async_validate_trigger_config(hass, config)
File "/usr/src/homeassistant/homeassistant/components/netatmo/device_trigger.py", line 87, in async_validate_trigger_config
raise InvalidDeviceAutomationConfig(f"Unsupported model {device.model}")
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Unsupported model Smart Indoor Camera
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 113, in _try_async_validate_config_item
validated_config = await async_validate_config_item(hass, config, full_config)
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 80, in async_validate_config_item
config[CONF_TRIGGER] = await async_validate_trigger_config(
File "/usr/src/homeassistant/homeassistant/helpers/trigger.py", line 100, in async_validate_trigger_config
conf = await platform.async_validate_trigger_config(hass, conf)
File "/usr/src/homeassistant/homeassistant/components/device_automation/trigger.py", line 69, in async_validate_trigger_config
raise InvalidDeviceAutomationConfig("invalid trigger configuration") from err
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: invalid trigger configuration
if I downgrade to 2022.9.7 the error disappear againg and everything work like before withouth touching any automation.
The problem is that now I’m stuck to 2022.9.7, is there anything I can do to try to solve this issue?
I am facing the same error after updating to 2022.10. When i restore to 2022.9.7 everything works.
But once i update Automations and Zigbee2mqtt are no longer available
2022-10-06 02:20:50.003 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: automation
2022-10-06 02:20:50.015 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: (DependencyError(...), 'Could not setup dependencies: automation')
Logger: homeassistant.setup
First occurred: 3:05:04 AM (1 occurrences)
Last logged: 3:05:04 AM
Error during setup of component automation
File "/usr/src/homeassistant/homeassistant/components/hue/device_trigger.py", line 44, in async_validate_trigger_config
raise InvalidDeviceAutomationConfig(f"Device ID {device_id} is not valid")
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Device ID c162359ed7df93641d0122b65a393798 is not valid
File "/usr/src/homeassistant/homeassistant/setup.py", line 235, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 246, in async_setup
if not await _async_process_config(hass, config, component):
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 690, in _async_process_config
await async_validate_config_item(hass, raw_config),
How to solve it?
Should i restore again to 2022.9.7 or is it possible to solve in 2022.10?
You are right, here’s my configuration.yaml (it needs some cleaning but it was working).
From what I see the issue seems related to the automations.yaml and not from some other configurations but since line 10 of configuration.yaml is related to “group: !include groups.yaml” and “automation: !include automations.yaml” is line 11 I’m a bit confused
I’ve run watchman report what was missing in automations.yaml, cleaned it up, but still not working.
Edit: And I’ve opened all of my automations, and checked triggers, and all seems ok. I’ve cleaned up also old blueprints which watchman has flagged, and still not working. So downgrade here I come.
First occurred: 08.39.58 (3 occurrences)
Last logged: 08.39.58
Invalid config for [automation]: invalid trigger configuration (See /config/configuration.yaml, line 159).
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Unsupported model Smart Outdoor Camera
I have the Netatmo Welcome and part of the problem seems there:
But when I updated the camera integration was working fine
It’s really frustrating. I’ve restored a Backup. Basically everythings running but i can not access the UI from my Add-Ons over the side bar. They are running but the status is on start-
I’ve tried to update to 2022.10.1 same error so far:
First occurred: 06:46:08 (1 occurrences)
Last logged: 06:46:08
I’m restoring the 2022.9.7 core backup. I really hope that the HA team will consider to fix this issue
