albeit without a calendar name listed, the actual events I made earlier are still no longer displayed.
There is no way we can get it to not show in the Dashboard menu, so, how do I do that
thanks. confess I dont grasp what that PR does just yet, but have faith you have fixed it cool, thanks for the swift and immediate action!
wait, I see it now, last state was always used. the PR should fix that per entity in the graph. And because showing several entities in 1 graph, it was as if the same state was colored differently on another entity/person. that should be fixed too then. Nice.
Yes, this was already deprecated in 2022.6 (so 6 months ago) and is now broken.
See the breaking change in the changelogs of 2022.12:
YAML configuration of MQTT entities under the platform key (e.g., light), which was deprecated in Home Assistant Core 2022.6, is no longer supported. The configuration must instead be done under the mqtt key.
The legacy MQTT device tracker is no longer supported. See the documentation for the supported MQTT device tracker configuration.
As of this release, you should now use the modern configuration schema for all manually configured MQTT entities. Please note that this does not impact MQTT discovery, for example, Zigbee2MQTT.
As a long-time user of Mushrooms I love the direction we are going, but i have to admit the change in colours did catch me out and took a while to fix. Detailing the exact css that needed modified would have been helpful, having the colour configurable on the frontend would have been better!
any chance we could up the granularity on the battery colors? experience shows that many batteries remain in the green zone for a long time, and only after lowering into the mid 50% or so, start accelerating downwards. Having more than 3 colors for high, medium and low is a ‘nice to have’
think:
icon_color: >
if (['unavailable','unknown'].includes(state)) return 'steelblue';
if (state > 75) return 'green';
if (state > 50) return 'gold';
if (state > 25) return 'orange';
if (state > 10) return 'brown';
return 'red';
I might have overlooked device_class: heat? was thrown off by the ‘off’ icon to be thermometer. So I didnt associate that with a heating device. Made a PR to change that to flame-off
Post your errors, It’s working for me. FYI reporting issues like this usually require all information, not abridged versions from the user. I.e. Post fully un-paraphrased errors accompanied with a description of what’s not working.
Source: components/hassio/http.py:111
First occurred: 07:32:58 (3 occurrences)
Last logged: 08:25:05
Error handling request
File “/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py”, line 433, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py”, line 504, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py”, line 117, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 60, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 100, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 28, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 81, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 236, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 136, in handle
result = await result
File “/usr/src/homeassistant/homeassistant/components/hassio/http.py”, line 75, in _handle
return await self._command_proxy(path, request)
File “/usr/src/homeassistant/homeassistant/components/hassio/http.py”, line 111, in _command_proxy
await response.prepare(request)
File “/usr/local/lib/python3.10/site-packages/aiohttp/web_response.py”, line 421, in prepare
return await self._start(request)
File “/usr/local/lib/python3.10/site-packages/aiohttp/web_response.py”, line 429, in _start
await self._write_headers()
File “/usr/local/lib/python3.10/site-packages/aiohttp/web_response.py”, line 502, in _write_headers
await writer.write_headers(status_line, self._headers)
File “/usr/local/lib/python3.10/site-packages/aiohttp/http_writer.py”, line 131, in write_headers
self._write(buf)
File “/usr/local/lib/python3.10/site-packages/aiohttp/http_writer.py”, line 76, in _write
raise ConnectionResetError(“Cannot write to closing transport”)
No idea where to change it and I will not build theme for scratch because some mad scientist came with bright idea of his own hardcoded colors not reachable in File Editor in HA
Using the Local calendar - is there a way to use the event title as a trigger? Like I have a vacuum cleaning scheduled to start at 12 o’clock and a heater at 11 PM. From what I see I can only create two separate calendars to distinguish the trigger? Also is there an option to edit an event? Like I want to start the cleaning at 7PM from now on.
