These are all good examples, and I’ve bookmarked this post for my future reference.
You are right, however, in that I was originally referring to an additional field added to templates, not unlike the one that already exists for determining how the availability of a sensor is handled, the availability field. My example was my attempt at trying to figure out exactly what you were talking about doing instead.
In reality, couldn’t the availability issue also be handled as you’ve shown above without that field. But there was some thought put into adding this field initially, before unknown as added as a state. I just thought it might make sense to consider doing the same to make it a bit more consistent. Clearly, you can do pretty much anything you need with a template somewhere, there’s no disputing that. That was all I was saying.
It really depends on the usage. For me, it hosts HA only. That’s it job. and I take great pains to optimize the installation (with what knowledge I have about HA), nothing iextraneous. The temps stay about where they were when I had the fan, but even then well below what is considered ‘normal’ operating temps, and far below where throttling would occur. In my case, and I’d guess in most typical HA instances (unless hats and GPIO connections are used, or powering an external USB drive), you likely don’t need a fan. But it is easy enough to add a fan without having to worry about controlling it with HA. My fans just plugged in and ran when it was on. I never felt the need to control the speed. That just seemed like unnecessary complexity to me. Just a data point, not saying this is the ONLY way.
The fan itself wasn’t noisy, it was the vibration of the fan in the case enclosure that drove me nuts. Had to go.
I’ll likely upgrade to Amber/Yellow whenever it is widely available and keep the pi for dev/test/backup.
Annoying thing is I only went to Python 3.9 (paid python package -dependency) to “future proof”. If I’d stayed on Python 3.8 it would never have attempted the update. You live you learn.
No it’s not QNAP per say, there are developers in France (qnapclub.eu) who have a third party repositary for lots of applications QNAP themselves don’t want to support e.g. Home Assistant, Radarr, Sonarr etc. The majority are free but recently they’ve started charging for the framework, for example Home Assistant (up to 2021.12) sat on Python 3.8 which they built on Apache + PHP8.0 and now the new one is on Python 3.9 which they built on Apache + PHP8.1. It’s only 5 to 10 Euro and “usually” takes a lot of the hassle out of it.
I’ve only recently started using docker and I’m running Readarr, Soulseek, Calibre, Room-Assistant, Pi-Hole, Tiny Media Manager and nGinx so it would seem the obvious next step.
Just worried about the amount of outbound connections HASS has and what a PITA it might be to get everything talking.
What this conversation has reminded me of is that when I moved over to the Python 3.9 framework I realised a week or so after that it was just one custom card that had killed my dashboard on 2021-12-10 as it happened again and I used method of elimination / last in - first out!
So… I’ve reinstalled the 3.8 framework, used the appropriate package for HASS, deleted that card and I’m up and running again.
Probably have to reverse a couple of changes but at least the bones are back. Still not ruling out docker if only to keep the version I want!!
Logger: homeassistant.components.binary_sensor
Source: components/mqtt/debug_info.py:82
Integration: Binary Sensor (documentation, issues)
First occurred: 11:10:58 (11 occurrences)
Last logged: 11:10:58
Error adding entities for domain binary_sensor with platform mqtt
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 382, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 614, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 778, in add_to_platform_finish
await self.async_added_to_hass()
File "/usr/src/homeassistant/homeassistant/components/mqtt/binary_sensor.py", line 121, in async_added_to_hass
await super().async_added_to_hass()
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 657, in async_added_to_hass
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 247, in async_added_to_hass
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 320, in async_added_to_hass
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 509, in async_added_to_hass
debug_info.add_entity_discovery_data(
File "/usr/src/homeassistant/homeassistant/components/mqtt/debug_info.py", line 82, in add_entity_discovery_data
debug_info = hass.data[DATA_MQTT_DEBUG_INFO]
KeyError: 'mqtt_debug_info'
Logger: homeassistant.components.switch
Source: components/mqtt/debug_info.py:53
Integration: Switch (documentation, issues)
First occurred: 11:10:45 (7 occurrences)
Last logged: 11:10:45
Error adding entities for domain switch with platform mqtt
Error while setting up mqtt platform for switch
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 321, in async_added_to_hass
await self._availability_subscribe_topics()
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 397, in _availability_subscribe_topics
self._availability_sub_state = await async_subscribe_topics(
File "/usr/src/homeassistant/homeassistant/components/mqtt/subscription.py", line 94, in async_subscribe_topics
await requested.resubscribe_if_necessary(hass, current)
File "/usr/src/homeassistant/homeassistant/components/mqtt/subscription.py", line 47, in resubscribe_if_necessary
debug_info.add_subscription(self.hass, self.message_callback, self.topic)
File "/usr/src/homeassistant/homeassistant/components/mqtt/debug_info.py", line 53, in add_subscription
