I have been using a client certificate to connect to my Mosquitto MQTT broker for some time.
My configuration.yaml has had
mqtt:
broker: mosquitto.host
port: 8883
client_id: home_assistant
certificate: '/config/root.ca.pem'
discovery: true
discovery_prefix: homeassistant
client_key: '/config/ha_mqtt.key.pem'
client_cert: '/config/ha_mqtt.cert.pem'
tls_insecure: false
and all has been fine. I now see that the connection details (broker/port) are deprecated and I should set this up via the integration.
Trying to do this just says unable to connect and I can never get past that first step in the config.
I have tried setting just the TLS settings in the yaml file (client and sever) and this does then get picked up as needing configuration but again it fails when I enter a host / port (but no username / password)
And going back to the old yaml setup is no longer picking it up so I am stuck without my MQTT broker which is used by most of the my entities
