So it looks like the stream component is still leaking in 2022.4.5. The leak is different from the 2022.4 one. It happens everytime I start a stream and let it stop after the 5 minute timeout. I’m not using preload. It doesn’t leak while the stream is running, but when the stream opens:
Every jump in the memory graph is when I start the same stream again (after letting it idle out). The big dip shortly before 22:00 is a restart of a clean 2022.4.5 install.
Can anyone confirm this before I open an issue on Github ?
