Trying to “Import from USB”, following this guide Debugging the Home Assistant Operating System | Home Assistant Developer Docs but now in the new UI structure i can not find Supervisor anymore ?
I was looking for him too and I didn’t find it anywhere. I’d be interested too.
Import from USB has been removed from the UI as it is a very advanced feature intended for developers only. You will need to use the cli for it now.
from my perspective it is not strictly “developers only”. I need to update the config.txt file to get the Raspbee 2 working ([SOLVED] Raspberry Pi + RaspBee II - HAOS Deconz integrations - Advice - deCONZ Community)
I know i can take the sdcard out and edit on another system but preferred the ssh route. Each OS update overrides the config.txt and i loose the Raspbee 2
The ssh route still works? The ssh addons (and the host if you’ve enabled host ssh access) all include the ha cli. You can still do this from there, it’s just been removed from the UI.
Here are some instructions to run it via the command line:
- Install the Terminal & SSH add-on
- Open the terminal and run the following command
ha os import
HERE IS THE REAL SOLUTION! Thank you!
