2022.7: A stunning performance
Yes something like that should be done. “Always run latest stable of controller and UniFi OS”
Same issue for me, CPU increases since yesterday. What’s the next?
brok my virtualbox vm 2 times unavalable wen upgraded from core 2022.6.7. to 2022.7.7 os 8.4 please fix
Hm… it works perfectly here. VM on Synology, haos 8.4 and lateset core version…
I had to uninstall mariadb, I wasnt using it however it was in my installed addons. Once removed, mysql worked fine!
thanks for fixing it :slight_smile: @adwoodworth
No such versions. Post properly.
hello
tanks for return to old version
i need ble for miflora !!!
3th of aug
There are bluetooth changes in 2022.8 2022.8: Beta release notes - Home Assistant
I was a bit scared of this update after reading through this discussion, especially since I’m running HA inside docker with mariadb as database.
I just upgraded to 2022.7.7 without any problems at all though, can recommend it :+1:
The Russound integration has been updated with python 3.10 support and should be fixed in the 2022.8 release.
Thanks! This solved my mysql connection issue
Anyone using the project “My Garden Irrigation V2” and having issues with it’s lovelace starting with 2022.7.x ?
I get unknown error only if I have that lovelace code in the YAML.
It is working fine until 2022.6.7
Hi @tom_l I’m veryyy new to HA and would appreciate some help. After updating to 2022.7 I’m having a number of issues. I can’t even get into my HassOS anymore. I connect to HA (Raspberry PI 400 running HassOS) via a browser window on my PC.
As I can’t log into HassOS, how/where do I issue that command you mentioned?
Many thanks.
Can you hook up a monitor to the pi?
Hi there, yes I can. It shows the Home Assistant “logo” and os version etc. Is this where I run:
ha core update --version 2022.6.7
And do I need to be connected to the internet for it to roll back?
Many thanks.
Yes.
Yes.
Really appreciate the assistance.
Agreed, an ALL or EVERYTHING option in new History tab should be mandatory! Soonest!
