2022.8 broke smart vents
I’m using some zigbee smart-vents with deconz and after the latest update I found they no longer work, telling me that its “unavailable” even though I can see it. In the logs, I get these errors, but I’m unable to figure out what it means.
Rolling back to 2022.7.7 fixed the problem, so its clearly something broke in the update.
2022-08-08 08:02:08.011 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 930, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 713, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/deconz/cover.py", line 88, in async_set_cover_position
    await self.gateway.api.lights.covers.set_state(
  File "/usr/local/lib/python3.10/site-packages/pydeconz/interfaces/lights.py", line 71, in set_state
    return await self.gateway.request_with_retry(
  File "/usr/local/lib/python3.10/site-packages/pydeconz/gateway.py", line 142, in request_with_retry
    return await self.request(method, path, json)
  File "/usr/local/lib/python3.10/site-packages/pydeconz/gateway.py", line 167, in request
    response: dict[str, Any] = await self._request(
  File "/usr/local/lib/python3.10/site-packages/pydeconz/gateway.py", line 194, in _request
    _raise_on_error(response)
  File "/usr/local/lib/python3.10/site-packages/pydeconz/gateway.py", line 225, in _raise_on_error
    raise_error(data["error"])
  File "/usr/local/lib/python3.10/site-packages/pydeconz/errors.py", line 73, in raise_error
    raise cls(
pydeconz.errors.RequestError: 6 /lights/8/state parameter, lift, not available
2022-08-08 08:02:26.499 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140415054376688] 6 /lights/4/state parameter, lift, not available
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 199, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1713, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1750, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 676, in entity_service_call
    future.result()  # pop exception if have
    await coro
    await result
    raise cls(
pydeconz.errors.RequestError: 6 /lights/4/state parameter, lift, not available
2022-08-08 08:02:32.476 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140415054376688] 6 /lights/4/state parameter, lift, not available
    task.result()
    await coro
    await result
    raise cls(
2022-08-08 08:02:58.064 ERROR (MainThread) [frontend.js.latest.202208020] :0:0 ResizeObserver loop completed with undelivered notifications.
Can’t say for sure whether this will help, but 2022.8.2 now out which includes a deconz fix.
Still broken in 2022.08.3.
