Since Repairs is build in and warned me that Spotify should not be in YAML so I removed the lines. When I try to add the Spotify integration I get the warning: INVALID_CLIENT: Failed to get client
Steps I tried:
- remove app from spotify dev and re-create it
- remove home assistant from apps in your normal account.
- looked for .spotify-token-cache and media_player.py but could not find them.
- tried https:/ /my.home-assistant.io/redirect/oauth as well as https:/ /192.168.0.2:8123/auth/external/callback in the spotify dev app. (I broke the link with a space between the // to keep the link visible)
nothing seem to work and all result in the same error: INVALID_CLIENT: Failed to get client.
I have no clue where to look anymore. I run Home Assistant supervised through Docker on a Debian bullseye machine.
can anyone help?
found the solution:"Spotify configuration error (INVALID_CLIENT: Failed to get client) - #19 by Mijn.Handen
Other than this… keep up the great work, stuff is getting better and better.
