Updating to 2022.9 forces update of zwave_js which disables control of my garage door. What I figured out that anything above 1.65 disables the garage door and also the my honeywell thermostat. Lights are ok. Any work around other than staying where I am at? Thanks.
This is in the release note for zwave-js:
This release comes with no breaking changes on UI side. However, the driver has been upgraded to v10, which seems to cause issues with some devices. After upgrading, please do the following:
- If a device does not work, re-interview
- If a device does still not work, go to zwave-js/node-zwave-js#4994
Thank you, I will give that a try…
