Exact what I was looking for.
Does already some one know, where the yaml file for this kind of helper is?
I try to have 30minutes slots, but the UI saves 60min, even I if I selected 30min.
If you’re talking about the scheduler integration then the things you don’t in the UI aren’t written to YAML you can edit. You can however just set it up in YAML.
There are also a bunch of bugs, one of which is being unable to display the schedule properly in the front end (30 minutes → hours, and sometimes it disappears altogether).
The Monday to Friday schedules here actually end at 08:30:
They do turn off at the correct time (08:30), they’re just not displayed correctly.
