2022.9: Home Assistant Birthday Release!
Suggestion/Request:
Automation/Scenes → Duplicate Can this be adjusted to how it was before the change and to include the original description with the word “Duplicate” on the end.
Reason: Being a duplicate saves having to rewrite the whole description.again which is a pain. As it stands one has to open another window to copy/paste it back in.
thanks for replying…
[{"id":"2ca985ad.7bceea","type":"tab","label":"Outdoor, Breezeway, and Basement Lights","disabled":false,"info":""},{"id":"cf01352f.551f28","type":"api-call-service","z":"2ca985ad.7bceea","name":"porch light 10%","server":"f9bed8a1.27e738","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.hue_front_porch"],"data":"{\"brightness_pct\":10,\"rgb_color\":[255,255,255],\"white_value\":80,\"transition\":10}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":840,"y":220,"wires":[[]]},{"id":"586c6d4b.41205c","type":"bigtimer","z":"2ca985ad.7bceea","outtopic":"","outpayload1":"on","outpayload2":"off","name":"Porch & Driveway Door Light","comment":"","lat":"43.201","lon":"-86.274","starttime":"5004","endtime":"5003","starttime2":0,"endtime2":0,"startoff":"-30","endoff":"30","startoff2":0,"endoff2":0,"offs":0,"outtext1":"on","outtext2":"off","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":"","month7":"","day8":"","month8":"","day9":"","month9":"","day10":"","month10":"","day11":"","month11":"","day12":"","month12":"","d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xday7":"","xmonth7":"","xday8":"","xmonth8":"","xday9":"","xmonth9":"","xday10":"","xmonth10":"","xday11":"","xmonth11":"","xday12":"","xmonth12":"","xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":false,"atstart":true,"odd":false,"even":false,"x":400,"y":180,"wires":[["c8e393af.fe94d"],[],[]]},{"id":"c7a37ba2.3bb2b8","type":"inject","z":"2ca985ad.7bceea","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":116,"y":153,"wires":[["586c6d4b.41205c"]]},{"id":"bcb4cb9e.1abbb8","type":"inject","z":"2ca985ad.7bceea","name":"","props":[{"p":"payload","v":"off","vt":"str"},{"p":"topic","v":"","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":110,"y":220,"wires":[["586c6d4b.41205c"]]},{"id":"443c7f3a.ce7198","type":"inject","z":"2ca985ad.7bceea","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"auto","payloadType":"str","x":110,"y":300,"wires":[["586c6d4b.41205c"]]},{"id":"be5d7871.f07358","type":"inject","z":"2ca985ad.7bceea","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"timer 5","payloadType":"str","x":110,"y":380,"wires":[["586c6d4b.41205c"]]},{"id":"c8e393af.fe94d","type":"switch","z":"2ca985ad.7bceea","name":"on or off","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":500,"y":380,"wires":[["cf01352f.551f28","3349dcdab4f42863","5e7cb876.932258","87584ddf6d629345"],["e1fc8d054edfd20e","3990b1deda2311b6","b6503f1d073f132d","89830b272911d604"]]},{"id":"5e7cb876.932258","type":"api-call-service","z":"2ca985ad.7bceea","name":"Driveway Light 50%","server":"f9bed8a1.27e738","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.hue_driveway_light"],"data":"{\"brightness_pct\":50,\"rgb_color\":[255,255,255],\"white_value\":230,\"transition\":10}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":860,"y":280,"wires":[[]]},{"id":"3349dcdab4f42863","type":"api-call-service","z":"2ca985ad.7bceea","name":"outside driveway door light 10%","server":"f9bed8a1.27e738","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.hue_outside_driveway_door_light"],"data":"{\"brightness_pct\":10,\"rgb_color\":[255,255,255],\"white_value\":80,\"transition\":10}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":890,"y":160,"wires":[[]]},{"id":"87584ddf6d629345","type":"api-call-service","z":"2ca985ad.7bceea","name":"breezeway and basement bulbs 1%","server":"f9bed8a1.27e738","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.garage_and_basement_night_lights"],"data":"{\"brightness_pct\":1,\"rgb_color\":[255,255,255],\"white_value\":80,\"transition\":10}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":910,"y":340,"wires":[[]]},{"id":"3990b1deda2311b6","type":"api-call-service","z":"2ca985ad.7bceea","name":"turn off porch light","server":"f9bed8a1.27e738","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.hue_front_porch"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":850,"y":500,"wires":[[]]},{"id":"b6503f1d073f132d","type":"api-call-service","z":"2ca985ad.7bceea","name":"Turn Off Driveway Light","server":"f9bed8a1.27e738","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.hue_driveway_light"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":870,"y":560,"wires":[[]]},{"id":"e1fc8d054edfd20e","type":"api-call-service","z":"2ca985ad.7bceea","name":"turn off outside driveway door light","server":"f9bed8a1.27e738","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.hue_outside_driveway_door_light"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":900,"y":440,"wires":[[]]},{"id":"89830b272911d604","type":"api-call-service","z":"2ca985ad.7bceea","name":"turn off breezeway and basement bulbs","server":"f9bed8a1.27e738","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.garage_and_basement_night_lights"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":920,"y":620,"wires":[[]]},{"id":"f9bed8a1.27e738","type":"server","name":"Home Assistant","version":4,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m"}]
found this in my node red logs…
9 Sep 00:00:19 - [error] [api-call-service:turn dining room lights on to red-orange 50%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn living room lights on to red-orange 50%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn night lights on to red-orange 20%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn bed room lights on to red-orange 50%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn dining room lights on to red-orange 60%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn living room lights on to red-orange 60%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn night lights on to red-orange 30%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn bed room lights on to red-orange 60%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn dining room lights on to red-orange 30%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn living room lights on to red-orange 30%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn night lights on to red-orange 10%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 00:00:19 - [error] [api-call-service:turn bed room lights on to red-orange 30%] Call-service error. extra keys not allowed @ data['white_value']
9 Sep 06:00:20 - [debug] [api-call-service:turn living area lights on to red-orange 10%] Calling Service: {"domain":"light","service":"turn_on","target":{"entity_id":
Screen Shot 2022-09-09 at 9.29.44 PM
probably find my answer there I bet
They can be discovered and added to HA via the Proxy yes, but they cannot currently be controlled. But that functionality is in the works.
Deprecated in version 2021.5, finally removed after an extremely long grace period. It’s been logging this for over a year but it seems you didn’t notice. Regardless you have to remove it now.
I use it every day. is it called something else now?
is it just called “white” now? is that the same?
Yes looks like it. Here’s the dev blog post informing developers of custom components what they have to do if they haven’t migrated away from white_value yet:
That also links this PR which talks about adding white as the replacement and some of the differences:
10 out 10 bro
I be doing that at home to nite
Hi!
When i try to setup Lametric, i get this:
{"error":"redirect_uri_mismatch","error_description":"The redirect URI provided is missing or does not match","error_uri":"http:\/\/tools.ietf.org\/html\/rfc6749#section-3.1.2"}
What can i do?
Thanks,
Jose
The UI keeps flickering for my cameras (the camera output is fine in other apps)… I am using the latest MS Edge (Chromium). I obscured the cameras for privacy but they flicker along with the card itself (picture entity). Using live mode for the cameras.
I just noticed, why did you remove all those sorts of useful info from the About page? I was just about to copy some diagnostic info here, I used to be able to see timings for integrations startup, platform, versions, etc… Now that info disappeared. I couldn’t find it on any of the menus. Not even on the developer tools. WTH stop trying to “apple”-ify HA. Removing diagnosis information is incredibly silly.
ezgif-4-e0c800ebfb
The logging looks ok to me and suggests the proxy is set up correctly (though seeing the yaml would have been nice). I have Xiaomi plant sensors working perfectly though the proxy. They needed to be updated to a recent Xiaomi firmware in order to work. I have no experience if ATC firmware is compatible enough to be autodiscovered by HA the same way. I fear that might be the problem. If Home Assistant itself has a bluetooth adapter, and the ble tracker from that does not recognise it too when held close, then the ble proxy won’t work either.
There is a catch that caught me confused for quite a while: one sensor wasn’t picked up (I thought). But after trying everything I could think of and pulling some of my hair out I figured out it had connected to HA before. I had decided to ignore it back then because it was working though an esp32 and didn’t connect reliably enough. Once I stopped ignoring it it was rediscovered and added perfectly. So maybe check the filter to show ignored devices!
It is now obviously, logical, easy to find and fast to each in Sytem->Repair->three-dot-menu → startuptimes.
And no, I don’t like this hiding of things in the last releases either. Old users only find them, because they know, it was there before (visible and usable). New users will only find this by chance.
Systeminformation as well. For me somehow perhaps overlapping, but most times not related to repairs at all and (for me) missplaces there. This should be at least in System → Info.
hi! in version 9.1 dont work “Next Tariff”
Correct, it don’t.
Use the select service instead.
Looks like this PR fixes it. Not sure what that means for all our automation…
Hi
I have the same problem with all the new versions coming up. They don’t have the system options to know the path of the devices.
And ofcourse a very persisting problem since the update from 2022.4.7 iam still unable to get my Conbee 2 stick to work with ZHA integration on RPI4. Whenever I update my system from 2022.4.7 I loose my ZHA integration and it fails to load. things I tried
  1. restarting around 5 times my RPI
  2. using specifically 2.4 USB 2 for conbee 2
and other line of codes which I found on community chats in here and github. But no solution yet.
only error setting up entry ConBee II.
Please help if possible will be really appreciated.
Not sure The new naming system is very useful, this is an auto-entities checking unavailable and finds several of the zwave devices …I did rename 1 entity to show the difference
I really hope you are being sarcastic for fun!!!
Yes, it should be on System > Info. That is logical and easy lol.
Hi ,
My “Supervised” system is flagged as “not supported” due to “cggroups versions” but the following link is broken " https://www.home-assistant.io/more-info/unsupported/cgroup_version "
Thank you
Awesome update!!! Love the Zwave Firmware updates!!! Thank you @AlCalzone
Docker Configuration - Home Assistant (home-assistant.io)
