tap_action:
action: call-service
service: input_select.select_option
service_data:
option: Home
entity_id: input_select.modes
well thatās the problem, youāre mixing up syntax. Target isnāt valid in the frontend (dashboards).
tap_action:
service_data:
option: Home
is that a new thing? because it worked for me up until now
Nope, itās always been this way.
weird. thanks anyway i really appreciate it.
Because the browser didnāt change, the version is the same as before the HA update. This only started after the update. I regressed to August the it doesnāt happen. Reinstalled September update and problem came back. So obviously itās HA not the browser.
Bluetooth intragration crashes after some time (<1h) Ā· Issue #78036 Ā· home-assistant/core Ā· GitHub is broken for me too.
Please be more careful when programming.
Please tell me someone who knows it for certain.
Currently people move their integrations from yaml to UI.
Is is obligatory? No.
Is it possible to maintain settings in UI & yaml in parallel? Probably yes; harder but still possible; and probably there is a way to āyaml settings - change in yaml only, UI settings - change in UI onlyā.
Similar questions are asked here many times.
And a situation becomes worse.
Check here: Actions - Home Assistant
Used "data"
instead of "service_data"
Outdated docs?
Earlier I used ādataā in ātap_actionā - and it worked.
Btw, here all 3 different "tap_action"
seem to give same result (i.e. toggling an "input_boolean"
type: entities
entities:
- input_boolean.test_boolean
- entity: sun.sun
tap_action:
service: input_boolean.toggle
entity_id: input_boolean.test_boolean
- entity: sun.sun
name: using service_data
tap_action:
service_data:
- entity: sun.sun
tap_action:
For instance, these both codes work for a template switch:
turn_on:
turn_off:
- service: input_boolean.turn_off
But for picture-elements card you are obliged to use "service_data"
instead of ātargetā:
- type: service-button
title: Button
style:
top: 6%
left: 20%
service: homeassistant.update_entity
service_data:
entity_id: sun.sun
So, 100500 different variants of calling a service.
There should be ONE way to define data when calling services - and it must be used in docs for examples (all of us may propose corrections in docs, btw).
Btw, got plenty of ārepair requiredā after update 2022.9.4 ā 2022.9.5.
These calls were considered as āwrong serviceā:
entity_id: input_boolean.xxxxxx
data: {}
Will see, may be will register an issue for this.
Here background, esp. not everything is possible in each case. I agree, that it would be great to have always only one multi-optional way, but here I see the problems of breaking changes for 99,9% of the users as well in removing the āoldā ways.
What? No. You completely miss-interpreted what I said.
Target isnāt valid in the frontend, i.e. under tap_action.
Itās valid in automation actions, template actions, blueprint actions, and script sequences.
So this is perfectly valid. Just not in the frontend.
service_data
was just changed to data
recently in tap_actions
. Before it required the verbiage service_data
. Now, service_data
and data
both work in tap_actions
. The docs no longer cover service_data
because thereās no reason to at this point. But your old tap_action
s will still work if they have service_data
and your new tap actions that just use data
will also still work.
Yes, see previous post.
Yep, and that background doesnāt cover tap_actions at all. They have a different history, but similar. Maybe someday the yaml in tap_actions will match the yaml for calling a service in the backend.
This post was not really addressed to you. It was basically about āwhy this code is considered as wring serviceā.
This difference makes a syntax confusing.
This would be good!
Check this code - ātargetā seems to work:
type: entities
entities:
- type: button
name: tap to toggle boolean
tap_action:
- entity: sun.sun
tap_action:
Interesting, that makes it mean that there is a bug. But based on the documents, itās unclear what the expected behavior is. So we donāt know where to file the issue. Iād just put it under core and let the devs figure it out. Either tap_action ā target should work everywhere and the documents should include target, or target should not work anywhere and the docs donāt need to be updated.
And in custom cards still the ātargetā is not used:
- type: custom:multiple-entity-row
entity: sun.sun
entities:
- icon: mdi:restore
tap_action:
show_state: false
Shows an error:
Could you post an issueās link here then?
Or I may try to create the issue myself, if you like.
Well, thatās custom:multiple-entity-row
not implementing tap action correctly. Iām pretty sure custom cards āreplicateā tap_action and donāt use coreās tap_action. Thatās what custom:button-card does and many others.
Right, bad example.
This card has own rules: GitHub - benct/lovelace-multiple-entity-row: Show multiple entity states and attributes on entity rows in Home Assistant's Lovelace UI
