Oopss!! I uninstalled the flux_led custom integration, I removed the repo in hacks and the lines in the light.yaml. I checked that the flux_led folder was deleted and when I try to intastall the integration, after a while this error appear
Failed to load configuration flow: {“message”:“invalid handler specified”}
Need I do something else to uninstall de custom integration?
Now I don’t really know where to ask this so I’ll just start here ;-). I’m running a few mi flora sensors through the native BLE feature. This works great! Except for the battery. I’ve got the feeling the batteries get drained pretty fast. I don’t really need an minute update for the moisture and don’t use the lux updates. So for me it would be fine to update the sensors every hour or so. Where can this be configured?
Feels like instead of keeping the description text in a scrollable area (with line brakes) the decision has made to just print it as plain text - which in the end removes the aimed add of overview and makes this pretty useless / unreadable, especially for longer descriptions…
You can now reorder automation elements using drag and drop. Thanks @piitaya
That is not working. I open an automation and can’t reorder e. g. actions. I only can use the overflow menu, switch to reorder and than reorder elements by clicking up and down arrows. There’s no drag and drop.
==> UI error?
Tried with Firefox and HA Companion app on iOS. Current setup:
